Old 04-01-2012, 07:50 AM
Danny King's Avatar
Danny King Danny King is offline
Default Found during condition inspection. Gear leg bolt n Nut
Uploaded with ImageShack.us
Bob Dean found one of his gear bolts hanging down when he pulled the cover plate for gear bolt torque check.
Here are the fact given to me by Bob.
1) Time on aircraft: 617 hours.
2) The torque on these bolts are checked once a year at my annual inspection.
3) I have never notice a problem, perhaps one of the bolts needed a little tightening over the years.
4) I had marked both bolts on both sides with Torque-seal to help detect movement.
5) The first picture with the bolt protruding is just the way I found it when I removed the inspection plate.
6) Inside the gear tower, the nut was totally off of the bolt. I cannot remember if the washer was still on the bolt or not. The bolt was sticking up through the gear tower; it seems like at least 3/16 of an inch, perhaps 1/4 inch.
7) I was using the the proper low profile metal lock nut. The threads were stripped, and you could see little metal filings.
8) The washer was the one that came with the kit. I am assuming that it is an AN960-616. As you mentioned they have replaced it with a 062 25783054.
9) The washer was bent. Hopefully, you can see it from the second picture.
10) The other bolt on this gear leg was loose. It took about a full turn of the bolt to get it properly torqued.
11) I have not properly check the other gear leg yet, but I do not see any problems from the visual inspection.
I am going to replace all four bolts with new bolts, new hardened washers and a new nuts.
Danny King
Beautiful Doll 80434 TT 1710 hours
I0360 A1B6 200 HP
Christen Inverted Oil
First Flight 12 July 2000
VAF Dues current for 2021
Old 04-01-2012, 08:04 AM
bird's Avatar
bird bird is offline
Default wow
I recieved my fuselage kit in June 2001. I am going to check to see which washers I have. This is a concern for sure. I wonder what caused this. Maybe they need to be inspected more often.
bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
Old 04-01-2012, 08:05 AM
RickWoodall's Avatar
RickWoodall RickWoodall is offline
Default Good catch
Good job doing a complete high quality annual. Seems some people skim through it with cursory looks etc. Taking the time and really going through each item start to finish and putting a wrench on things is the key.
Glad you found this and are fixing it properly. Hope your post gets others to dig deep and check.
Blue skies.
Rick Woodall C-GSTT "ghost"
9a -TMX io-320, catto three blade, dual dynon hdx with a/p. 900+ hrs in 8 yrs flying.
Flew to Osh 11,12,15,17,19. SNF 2013. West to Cali /Washington/Vancouver/crossed the Rockies north to Red Deer east to Moosonee and over to maritimes. South to Jekyll Isl, cedar key, and Key West etc. 7 trips and 17 islands of the Bahamas. Flown turtles and dogs for Pilots n Paws too. Love our Rv's
Old 04-01-2012, 09:25 AM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
If this is a bolt that holds the landing gear to the airframe, I know of one RV-8 that had a gear collapse during early take-off roll due to an APPARENT bolt(s) failure.
Airframe rebuild. Engine rebuild. New CS prop.
Old 04-01-2012, 09:58 AM
az_gila's Avatar
az_gila az_gila is offline
Question
Doesn't this imply incorrect initial assembly? A cross thread or over-torque?
Stripping threads is an unusual failure mode for a correct bolt joint isn't it?
If the nut is actually overloaded in an axial direction, then perhaps it should be a normal high profile nut and not a low profile one....
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-01-2012, 10:50 AM
Bob Kuykendall's Avatar
Bob Kuykendall Bob Kuykendall is offline
A couple of years ago, Steve Smith and I ran a series of tensile tests on the various types of nuts applicable to the RV-8 landing gear. The results are discussed in this thread:
http://www.vansairforce.com/communit...d.php?p=320444
Edit Add: Here's the money shot:
Thanks, Bob K.
Bob Kuykendall
Low-drag wingtips for RV-4 through RV-8
EAA Technical Counselor
Old 04-01-2012, 11:17 AM
az_gila's Avatar
Thumbs up
<pic snip>
Thanks, Bob K.
Thanks Bob,
This post's failure fits right in with the above linked post and puts your tests right into perspective.
Gil Alexander
Old 04-01-2012, 01:02 PM
sf3543 sf3543 is offline
Default one more point
There is one essential item that hasn't been discussed in this scenario. Bob and I discussed the failure and one point mentioned was that the washer was bent. In this case, the washer was ground down on the side so it would fit inside the radius of the longeron angle, as is often the case. Somewhere along the line, probably at initial installation, the washer got turned and was sitting at a slight angle when the bolt got torqued. I'm guessing that over time, the washer began to bend more to make itself fit into the radius of the angle, thus slightly loosening the nut and allowing it to work and wear. It doesn't take much to make this happen. At any rate, regardless of retorquing the nut every year, if the washer allowed even the tiniest gap, in my opinion, that would cause the failure of the nut over time
As a point of interest, Lycoming calls out that no paint is allowed beneath the cylinder nuts when torquing down cylinders since the failure of the paint over time could destroy the proper torque of the nut and actually cause the cylinder to come off the engine. (It has happened!)
At any rate, this discussion is a good lesson in why we need to do thorough condition inspections at regular intervals. You just never know what will happen next.
Steve Formhals
A&P, Tech Counselor & Flight Advisor
Multiple RV builder and currently
RV3B
Legend Cub
Old 04-01-2012, 09:51 PM
DanH's Avatar
DanH DanH is offline
Tom Brink @ GAHco has (or had) the required one size longer bolts if you want to use the easily obtained MS21045-6 nuts.
....and if I may....good call Smith and Kuykendall!
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-01-2012, 11:23 PM
GAHco's Avatar
GAHco GAHco is offline
Default Thanks for the refferals!
....and if I may....good call Steve Smith!
We also have the NAS1804 series of 12 point nuts.
http://www.gen-aircraft-hardware.com...f/Locknuts.pdf
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
