Go Back   VAF Forums > Model Specific > RV-9/9A
Old 03-29-2012, 02:25 PM
diamond diamond is offline
Default What else to order with 9 wing kit
When ordering a 9 wing kit, what else should be ordered at the same time so as to save on freight? Of course I don't want to spend alot of money for an item that costs very little in freight and won't be needed for 3 or more months down the road.
Old 03-29-2012, 03:09 PM
mikehoover's Avatar
mikehoover mikehoover is offline
Vans will ship the long lengths of aluminum angle used in the fuselage kit with the wing kit since the wing spar box is so long. Just be sure to identify it during inventory and store it for later.
Mike Hoover
Columbia, SC
www.aclog.com/rv-9a/
www.eaa242.org/
N194MH first flight on 08-26-12
Old 03-29-2012, 03:32 PM
Jeff R's Avatar
Jeff R Jeff R is offline
2 cans of pro seal
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
Old 03-29-2012, 05:08 PM
Greg Arehart's Avatar
I don't remember what kit, but be sure to get the wing root fairings. When you first fit the wings and set angles, make sure you fit and drill these at the same time as it will save putting the wings on again later just for fitting the fairings.
Greg
Greg Arehart
N 7965A
Old 03-29-2012, 05:33 PM
longranger's Avatar
I asked this question a couple of months ago about the 7. Probably similar answers for the 9.
http://www.vansairforce.com/communit...ad.php?t=81194
RV-7 TU 904KM (reserved)
Construction Log
Old 03-30-2012, 12:54 AM
o2flymy6 o2flymy6 is offline
Default My 2 cents
I might hold up on the pro seal order as it is a date sensitive product and it will be a bit before you need goo. Nothing more is really needed from Van's but you are going to be buying some tools you never thought of and that will save you time and headaches. One last thing to start considering is your wiring method as you might possibly need to drill wing ribs shortly to run wiring in the wings down the road (per Van's service bulletin).
Old 03-30-2012, 06:55 AM
Scbado Scbado is offline
Default 2-Fuel Caps
You may want to think about the Delux Fuel Caps. They cost $100.00 each (none key lock) but IMHO they are well worth it. I just received mine and I was very impressed. My wife also thought they are worth the $$$. I think that Vans will also give you credit for the standard caps that you will not be getting so now the value is even better
Jerry Roeder
C150 N222PA at 02C
RV-9A Standard Build Slider
Empennage done
Left Wing built
Right Wing built
Fuselage in process
Finish kit received
Moved Project to 57C
Old 03-30-2012, 07:02 AM
I agree. I have a brand new un-opend can that was out dated by the time I got to needing it but I have no idea how quickly you build. Figure on about 3 to 4 months of usable shelf life buy the time you get the can.
Jerry Roeder
C150 N222PA at 02C
Empennage done
Left Wing built
Right Wing built
Fuselage in process
Finish kit received
Old 03-30-2012, 11:19 AM
AF_Alan's Avatar
AF_Alan AF_Alan is offline
Default Tank test kit
When you order the proseal for the tanks (now or later), I'd also get the tank test kit. It is a balloon, pipe cap and fill valve. Really good feeling to wake up the next morning and see the tank didn't leak. Success makes working with the goop a bit less of an aggrevation.
If you'd like a cross reference inventory of what raw stock is used to make which part in the fuse, drop me a line at wiederaj 'at' yahoo 'dot' com.
Alan
RV-9A N984AW
Old 04-02-2012, 02:28 PM
kbehrent's Avatar
kbehrent kbehrent is offline
I bought half sheets(4x4) of .032 and .024 aluminum sheets along with a variety of sizes if angle. Ended up using almost all of it on a variety of brackets, mounting plates or just re-doing things I screwed up. van's prices on aluminum is really cheap compared to going to a metal store and buying it!
I wouldn't worry too much on the proseal, you can keep in frig and it will last a long time. My tanks don't leak and I used "expired" proseal. Heck, it was almost expired when it arrived from Van's.
When ordering up your wings, now is a good time to consider wiring, wiring conduit, lights, etc. If you are going to get them from Van's anyway, include them in your order.
If you are going to buy a autopilot, better be making up your mind on which one because you will want to mount the brackets for it while the skins are off. Same applies to the Pitot tube as well.
Kevin Behrent
TeenFlight Puyallup, President
www.teenflight.org
http://facebook.com/teenflightpuyallup
EAA Chapter #326
Puget Sound, WA
RV-9A
Aerosport (Superior XP) IO-320 C/S, Precision Eagle EMS
