Old 03-28-2012, 02:57 PM
rv6n6r's Avatar
rv6n6r rv6n6r is offline
Default Flaps wired to battery?
I'm in the midst of a panel upgrade project in my 13 yr. old RV-6 which involves rewiring pretty much everything... and I was thinking about the fact that I often extend or retract the flaps while the plane is shut down. Which involves turning on the master and unnecessarily powering up all the other non-avionics items... so why not wire the flaps directly to the battery? Safety-wise it doesn't seem like an issue (after all, manual flaps are "active" all the time). What other up or down-sides might I be missing? Has anyone else wired their flaps up this way?
Randall Henderson
RV-6
Randall Henderson
RV-6 / O-360 / CS, 1500+ hrs, 1st flight Sept. 1999
Airport committee chairman & ASNV for Seaside, OR Municipal (56S), www.seasideairport.org
Donated August 2020
Old 03-28-2012, 03:02 PM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
I remember reading this discussion in the forums a few years ago, but I can't remember the particulars. I know there were some pro's and con's discussed. I suggest you do a search of the forums and see if you can find that old discussion. Of course, a new discussion won't hurt either.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 03-28-2012, 03:03 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
If you do this, dont forget to put in a circuit breaker.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-28-2012, 03:05 PM
NickAir's Avatar
NickAir NickAir is offline
Location: McMinnville, Oregon: HOME of the SPRUCE GOOSE
Default Wiring Flaps
Just a thought.
Maybe wire the panel with an additional, "Avionics," switch.
This way you can power up the system and not power your sensitive glass and radios. Good for eliminating the surge on every start up. Flaps' trim, etc. not on the Avionics circut. Mine is wired this way and I love it.
All electronics are powered down when the Master is off. This is for safety regarding a crash, reducing sparks with possible fuel present.
Tailwinds...
Simplicity is the ultimate sophistication.
Leonardo Da Vinci
Working on a RV-4
Citabria 7GCBC
Cessna 180
RV7 I0-360 C/S, Slider, AP, Glass, etc. sold.
RV6 O-320 F/P, Slider, AP, Steam, etc., sold
Citabria 7KCAB rental
Piper Cherokee, sold
Sparrowhawk, sold
Proud -VAF- Supporter - Exempt, Dues Paid Anyway.
Old 03-28-2012, 03:12 PM
Wayne Gillispie Wayne Gillispie is offline
I have a hot battery bus in front and rear. Both are for accy plug/charge ports, led cockpit/panel lighting(I like it too, may not if they are left on), efis clock power. It can be wired like that and would be handy for planes without separate aux ebus battery. When I hit the master only my Dynon D-6 comes on. It may pose a safety hazard if someone is working near the flaps and the switch gets bumped accidentally or around children.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 03-28-2012, 03:51 PM
SMO's Avatar
SMO SMO is offline
Default Yup
When I reworked the panel of my -4 a couple years ago I wired the flap switch to the battery bus (I have 6 fuses on that bus). I like it, haven't seen any down side.
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
Old 03-28-2012, 04:11 PM
rv6n6r's Avatar
Thanks, I tried a search before posting, it didn't turn anything up but if anyone can point me to that, please do so!
Randall Henderson
Donated August 2020
Old 03-28-2012, 05:24 PM
Sam Buchanan's Avatar
been here awhile
Randall Henderson
RV-6
Randall, I've had my flaps "hot-wired" to the battery (via a fuse) since I upgraded to electric flaps many years ago. I've never regretted that decision and it is very convenient to be able to move the flaps without turning on ship's power.
I haven't found any downsides to this method.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 04-04-2012, 11:10 AM
rv6n6r's Avatar
Thanks all for the feedback. I'm going with it (including a fuse, of course!)
Randall Henderson
Donated August 2020
