03-28-2012, 06:07 AM
O-320 max rpm's
What size prop should i have on my RV-3? What should be my max rpm in flight and max static rpm?
Eric
N80wd
03-28-2012, 06:47 AM
been here awhile
Eric
N80wd
The metal Sensenich is a nice prop. Details Here:
http://www.vansaircraft.com/cgi-bin/...oduct=sen-prop
The prop is limited to 2600 rpm but is very efficient.
03-28-2012, 08:55 AM
Eric,
A 68" x 70" is pretty common. BUT, it depends what you want-Cilmb/Race or Cruise. That determines the final numbers. Typical static is around 2400 and WOT is 2700. I do have customers that are comfortable with WOT of 2900-3000 or more (this can lead to less TBO though). Hope this helps
Frank
RV6-N164FJ sold sadly
Legal Eagle w/Verner 3VW
Rans S7s
RV4- in progress
03-28-2012, 10:43 AM
been here awhile
Originally Posted by PropMan
Eric,
70" pitch? Vans recommendations for the O-320 in a RV-3 is 70" diameter and 81" pitch. I fly this prop on my O-320 RV-6 at 80" pitch; rotation at 2280rpm and I see 162 kts at the 2600rpm prop redline. The light RV-3 would really be a performer with this prop.
Frank, your props may be measured differently than the Sensenich but I didn't know there would be that much difference in the numbers.
03-28-2012, 11:36 AM
Yes Sam- Mine are measured differently. My O360 -6 has 65"x74" Three-blade and Static is 2400, WOT is 2700 at 210mph indicated at 3000'
Frank, your props may be measured differently than the Sensenich but I didn't know there would be that much difference in the numbers.[/quote]
Frank
Rans S7s
RV4- in progress
03-28-2012, 05:30 PM
been here awhile
Ahhhh...three blade, ok, we are comparing apples to oranges.
04-01-2012, 02:13 PM
prop size
I pulled the spinner off the other day and found my prop to be a 67"dia x 68 pitch. I don't know who manufactured the prop, but it has over 30 laminates. I get 2400 static, which I think is a little high and my digital tach goes between 2760 and 2850 rpm in flight.
04-01-2012, 02:48 PM
It is useless to compare pitch between different prop manufacturers. Especially wood.
Besides differences in measurement techniques, there are different airfoils and different plan-forms.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
04-02-2012, 03:55 AM
Sam, what make prop do you have? I have a friend with an Ed Sterba on a RV-3 that is a 68" x 75 pitch.....but his O-320 has 175 hp. I wanted a Amur-Demuth, but mike Demuth passed away in Feburary, I hadn't called the shop to see if it is still open for business.
Eric Venissat
RV-3
N80WD
04-02-2012, 07:09 AM
been here awhile
Eric Venissat
RV-3
N80WD
Have the metal Sensenich, 80" pitch per Vans recommendations. It is a cruise prop but my RV-6 (O-320, 160hp) still climbs nicely.
