Old 03-26-2012, 02:11 PM
hlangebro's Avatar
hlangebro hlangebro is offline
Default Lycoming O-320 D1A or D3G?
I am in the process of buying an engine for my -7A. I was planning on a O-320-D1A, however I found a E2A that has been modified to a D3G. Is there something I should be aware of here? I am planning on using the Short James cowl and plenum. Is there a fit issue? A far as I can tell, they are pretty much the same...
Hakan
Old 03-26-2012, 07:20 PM
jrs14855 jrs14855 is offline
Default E2A
The E2A has the "good" two piece front main bearing as in D series. The E series engines had plain steel cylinders as opposed to nitride in the D series. If the conversion was for a certificated application the cylinders should be nitride or plated. Probably lots of homebuilts flying with 160 hp plus with the steel cylinders.
Dimensionally the E and D series are identical.
Old 03-26-2012, 07:25 PM
Default E2A
Investigate the Lycoming 505 service bulletin before spending money. Lots of non airworthy crankshafts in engines for homebuilts. I personally have no issue with this with a wood prop, wood composite or composite constant speed. The DAR who certifys your airplane may have a different opinion.
Old 03-27-2012, 01:55 AM
NickAir's Avatar
NickAir NickAir is offline
Location: McMinnville, Oregon: HOME of the SPRUCE GOOSE
Default Engine
Just a thought.
My RV6 had a D3G with the hollow crank. You may know that the hollow crank is needed for an oil actuated C/S Prop such as the popular Hartzel. A big selling point down the road, even if you apply a fixed pitch the option is still there.
Tailwinds...
Simplicity is the ultimate sophistication.
Leonardo Da Vinci
Working on a RV-4
Citabria 7GCBC
Cessna 180
RV7 I0-360 C/S, Slider, AP, Glass, etc. sold.
RV6 O-320 F/P, Slider, AP, Steam, etc., sold
Citabria 7KCAB rental
Piper Cherokee, sold
Sparrowhawk, sold
Proud -VAF- Supporter - Exempt, Dues Paid Anyway.
Old 03-27-2012, 12:38 PM
mahlon_r mahlon_r is offline
The D3G and the D1A should be identical except the D1A should have a prop governor drive and plumbing installed, as it was originally shipped as a constant speed engine and the D3G would have the provision to mount the prop governor drive and the plumbing however the parts would not normally be supplied with the engine as it was originally shipped as a fixed pitch engine. So if you made the D3G constant speed by adding the CS stuff they would then be the same.
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 03-27-2012, 03:07 PM
hlangebro's Avatar
Default Still pondering
Thanks a bunch guys. I guess the price is reasonble ($8300) and compression is 77-79 on all. My concern is the camshaft and lifters. The engine has basically laid around since april -10, not pickled. Granted, it is in Arizona. The engine was run in march -12 and according to the shop in ran well.
