Old 03-26-2012, 03:07 PM
Vern's Avatar
Vern Vern is offline
Default Nose Wheel Pant broke in Half !
[IMG][/IMG]
This happened on landing. The rear broke in a clean line and was on the runway.
Aircraft had just passed 500 hours recently.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 03-26-2012, 03:16 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Wierd
At least it will be easy to repair.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-26-2012, 04:26 PM
Pat Stewart Pat Stewart is offline
Originally Posted by Vern View Post
[IMG][/IMG]
I would call Vans, fiberglass does not break that way unless laid up that way, manufacturing defect.
Old 03-26-2012, 05:20 PM
Michael White's Avatar
[IMG][/IMG]
Dang speed bumps!
Moose
VAF #136
Old 03-26-2012, 05:24 PM
DanH's Avatar
DanH DanH is offline
I've seen that before.....the airplane parked next to mine at OSH last year had the same break.....something about a shimmy on landing.
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-26-2012, 07:12 PM
Default Agree with Pat
I have done more than my share of fiberglass work and I have never seen a break like that. Somewhere in the production, it looks like something went wrong. I believe it would be difficult to cut the pant that straight with a grinder.
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
Old 03-26-2012, 07:23 PM
burgundyja's Avatar
burgundyja burgundyja is offline
termites
Mike Johnson
8A N484M
Old 03-26-2012, 08:07 PM
rvbuilder2002's Avatar
Severe shimmy was going to be my first guess.
Check the nose fork friction and let us know what the value is.
Old 03-26-2012, 08:11 PM
vfr800 vfr800 is offline
Default Chock-induced?
Just a thought... Is there damage right where a chock would rest behind the nose wheel? Tough to tell for certain the the pics, but the chock lines up with the break it seems.
Starting the engine with the chock aft of the wheel can cause the nose to squat down with the fairing getting damaged, possibly causing a weak spot that gave out during the landing roll.
Probably not the cause, but if there's any aligned indentation on the underside and this history it could be contributory. My 2 cents, and may be worth less!
Ryan M
VAF donation next due June 2022
(Exempt but worth it!)
Prior partner in RV-9a & RV-10
Now flying RV-10 #40515
Old 03-26-2012, 08:45 PM
TSwezey TSwezey is offline
[IMG][/IMG]
Were you at Signature at PDK? Mine cracked in half just like that. The line guys at signature rammed a chock up the back of the wheel. I left half of it on the center line at Savannah. I had to tell a USAir flight to go around.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
