03-26-2012, 01:03 PM
Preferred type of RTV / adhesive for conduit
Hey all-
I'm running some of the conduit that Van's sells (corrugated plastic). Is there a preferred or recommended type of RTV or adhesive for rib pass-thrus? Does it matter? There are like 50 types of RTV and I'm trying to make a good all around decision.
Thanks all.
03-26-2012, 01:05 PM
Senior Curmudgeon
I use Shoe Goo, not RTV.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
03-26-2012, 01:16 PM
I like Amazing Goop. I've used it on the conduit and also to stick down zip tie mounts. Works well.
Kelly Johnson
San Jose, CA
RV-9A
Pink slip issued: 5/7/12
Phase I Complete: 8/18/12!
2020 donation: complete
03-26-2012, 02:02 PM
Dow Corning 3145 RTV
It is "kinda" expensive but it's a MIL spec sealant/adhesive that works really well, and it does not dry up in the tube so you actually get to use most of rather than throw it away.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
03-26-2012, 02:15 PM
When you build the fuel tanks (or rudder), just use leftover proseal.
RV-7 TU 904KM (reserved)
Construction Log
03-27-2012, 09:09 AM
Thank you all-
I' went with the Dow Corning 3145 RTV Walt suggested. After some research and comparison the temp ranges and adhesion properties of the 3145 meet & actually exceed my requirements. With dark paint, some areas (the emp tips) might get pretty hot in the south if in the sun for a while. Better off safe then sorry later on. Thanks VAF!
