Old 03-25-2012, 01:02 AM
flyingtaran flyingtaran is offline
Default HS702 - HS710/714 Rivet Orientation
Hi all
just spent ages trying to understand the attachment of the HS-
710 and 714 to the HS 702. The plans call out for the
center four rivets to be attached with the flush heads aft, it doesn't state how the universal head rivets should be orientated, does this mean that the uni heads should be fwds,
thanks in advance
Taran
RV7 Under Construction
VH-TJL
Sydney Australia
http://www.mykitlog.com/flyingtaran
Old 03-25-2012, 07:21 AM
Mel's Avatar
Mel Mel is offline
Orientation is not critical on universal head rivets. Typically you want the shop head on the side of the thicker material for minimum distortion but again, it's not critical.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 03-25-2012, 07:55 AM
Lemmingman's Avatar
Lemmingman Lemmingman is offline
I asked the same question, at the same phase of building. Someone told me that a good rule of thumb is to follow what the diagram says and it will almost always work fine. The diagram will say something like:
AN470AD4-6 all HS-710 or HS-714 to HS-702 rivets. If you pass the rivet from the 710 to the 702 the factory head will be on the 710 (the thicker piece) and the shop head will be on the 702. This rule of thumb works most of the time, but always use your judgement.
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
Old 03-26-2012, 01:43 AM
thanks for the help guys
i got them in no problem today
Taran
VH-TJL
Sydney Australia
