03-25-2012, 12:16 AM
Thoughts on Titan ECI 180HP FI
Considering buying a partially finished RV7 with a Titan ECI 180HP FI engine. The engine was built from a kit by a well known local engine builder.
I will really appreciate a few recommendations and or thoughts from owners as I have not seen one before on an RV South Africa. We have checked that the cylinders are not affected by the AD on the cylinders - good news at least.
We want to use the 72" Hartzell blended airfoil prop Vans offer, on it. The crank is hollow and there a CSU pad at the back. Are there any other issues?
Much appreciated.
Jan Hanekom
South Africa
Approved Person nr 325
http://www.rvbits.com
RV10 - ZU-XOX - (Flying)
RV7A - ZU-JRV - (Flying)
RV10 - ZU-JVR - (Written off)
RV7 - ZU-LOL - (Flying)
RV10 - ZU-RVI - (Flying)
RV7A - ZU-MER (Bought back)
RV7A - ZU-JAD (Sold Flying)
Dues paid for 2020 WITH A SMILE
03-25-2012, 04:05 AM
ECI IO360 FI
I have that same engine, built by America's Aircraft Engines, in my RV8. I am nearing completion and hope to fly this summer.
I believe the engine and ECI components will be great, it's a lycomingclone. It is spec'd to make 188 hp and should easily run LOP with the uniform distribution of fuel delivery. The ECI fuel injection system is not main stream and requires a little modification to the throttle bracket to make it work and fit. You'll also need a fuel return line back to your tank and valve, I used the Andair duplex.
Bud Smith, RV-8, ECI IOX360 , Dual PMags, Dynon SkyView, Whirlwind 200GA, IFR and N88ZP has "slipped the surly bonds of earth".
03-25-2012, 05:21 AM
I have it too. Mattituck made mine. I have the Superior FF sump and Precision FI. Other than that it is the same.
Your exhaust is different from the Lycoming M1B and you will need to contact Larry Vetterman directly and inform him that you have this engine and he makes the appropriate changes to the exhaust. Aside from that the other differences are insignificant.
My friend has the same engine in his -7 and it runs like a scalded cat!
You will be happy!
 CJ
The experiment works!
03-25-2012, 07:11 AM
Same engine
Same engine in mine, also built from the kit. Mine is carburated but runs really well, so far 190 hours and recent compression checks were 80/79 on all four cylinders, I use Phillips XC and camguard. Only suggestion I would make is to make sure the pushrod tube retaining clips are superior or lycoming parts as the ECI parts broke frequently (all 4 in my case)
03-25-2012, 11:09 PM
Bud, is it possible to expand a bit here or point me to your builder's log pictures?
Done - it has a 4 pipe system from Larry installed.
Are these under the cover and secondly what does it involve to change these. Please explain if you can.
Jan Hanekom
South Africa
03-26-2012, 07:05 AM
Under the covers
The clips are under the covers, easy to change. If you search the forums there was a number of threads on this issue about a year ago
03-26-2012, 07:16 AM
If you want a good look at the fuel return system required for the ECI fuel injection system check attawayair.com
He has pictures of the installation of that type system along with a description. What he has written only applies to the ECI system.
George
03-28-2012, 12:44 PM
Great info on ECI's website
Take a look at this installation manual from ECI, about page 8 is all the info about the hardware needed, installation of the return line and the duplex andair valve. http://www.eci.aero/exp/RV8-8A.pdf
Good luck. Here's a few photos I just took:
[IMG]  By dbuds2 at 2012-03-28[/IMG]
03-30-2012, 07:51 AM
Can an Airflow FI system be fitted
Thanks for all the help so far!
Another question - can an Airflow FI system be fitted to this engine without any, or minimum modifications?
Jan Hanekom
South Africa
03-30-2012, 02:23 PM
Here ya go.
Here's Airflow's contact info:
864 576 4512 ask for Don Rivera.
He matched my injectors so I can run LOP...great guy.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
