Old 03-22-2012, 02:38 PM
RickWoodall's Avatar
RickWoodall RickWoodall is offline
Default Wing root weatherstripping adhesive?
My plane is painted, i have to go put it back together and i have brand new rubber weatherstrips to glue on. Just dont want to make a mess. What are all of you doing to secure the ends and is it holding up well?
I do have the fancy 3m weatherstrip yellow goop but was not really happy with it the first time around. Should it adhere just fine to the finished paint?
Any words of wisdom?
Rick Woodall C-GSTT "ghost"
9a -TMX io-320, catto three blade, dual dynon hdx with a/p. 900+ hrs in 8 yrs flying.
Flew to Osh 11,12,15,17,19. SNF 2013. West to Cali /Washington/Vancouver/crossed the Rockies north to Red Deer east to Moosonee and over to maritimes. South to Jekyll Isl, cedar key, and Key West etc. 6 trips and 17 islands of the Bahamas. Flown turtles and dogs for Pilots n Paws too. Love our Rv's
Old 03-22-2012, 02:57 PM
DEWATSON DEWATSON is offline
Default adhesive
The 3M adhesive comes in black too and both hold very well. Once you learn how to apply it, it is hard to beat. Get comfortable with everything in front of you on the workbench and open the weatherstripping and insert the tip of the tube in the slot. With a relatively small hole in the tube spout, squeeze the adhesive in half of the weatherstripping and immediately apply it to the fairing. Let it dry. Once dry, do the other half and let it dry. It's good stuff. Good luck.
Old 03-22-2012, 04:15 PM
Default I agree
I flew without it at first and at modest speeds it was OK that way but at higher speeds during pull ups after a finish line for example, if it isn't glued down it will pull out and beat on the plane like a drum. I used 3M yellow after the second or third occurrence and no problem since. Think of contact cement and not regular glue when using it. Paint is not a problem.
Bob Axsom
Old 03-23-2012, 03:51 AM
s24789 s24789 is offline
Default Clthes pins
We initially used clamps and pieces of scrap Al to apply pressure while the glue dried. Eventually bought 100 clothes pins to make sure we got a good seal. No issues
Phelps
Kevin Phelps
Paid thru Dec 2020
RV-7A flying N782WP
Stuart, Fl
Old 03-23-2012, 06:04 AM
DanH's Avatar
DanH DanH is offline
I am a huge fan of Pliobond. Buy it in the brush can and thin with MEK as desired.
http://www.aircraftspruce.com/catalo...s/pliobond.php
Pliobond is also the hot ticket for securing a front main seal.
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-23-2012, 06:18 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I am with Dan....PlioBond!
I was introduced to it when I was taught to recover Cubs about four decades ago, so it smells like history to me..... called out by name in many of hte better maintenance manuals through the years!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 03-23-2012, 07:10 AM
Jaypratt's Avatar
Jaypratt Jaypratt is offline
Default Ttito Pliobond
I use Pliobond too. Get it from Aircraft Spruce, Wag Aero, Wicks,,,
Jay Pratt VAF #2
RV Central - Builder Assistance
Paul Revere, Borrowed Horse, & Shooter
Old 03-23-2012, 07:31 AM
woodmanrog's Avatar
woodmanrog woodmanrog is offline
Default No glue needed
On my past 3 RV's, I have found that if the 1/8" spacing between the wing root fairing and the fuselage is maintained, the supplied rubber insert will not come loose even at around 4 g's. If this space is larger, you will need glue.
Old 03-23-2012, 07:32 AM
Don's Avatar
Don Don is offline
Default Additional Pliobond benefits
Pliobond has other uses, too. If you're a fly-tier, pliobond can also be used to reinforce wings tied from turkey, duck, and other primary flight feathers making them much less fragile.
The yellow glue others use is just plain nasty to work with, in my opinion. I put a door seal on my Cherokee with it 8 or 9 years ago and most of it has finally worn on my hands and arms where it inadvertently ended up. The door seal is doing fine.
Don Alexander
Virginia
RV-9A 257SW Purchase Flying - O-320, Dynon D100
RV-9A 702DA (reserved) Finish Kit IOX-340
www.propjock.com
Old 03-23-2012, 07:55 AM
I don't recall that being the word that came to mind the first time I took a whiff of the stuff when bonding the baffle seal on the cowl inlet.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
