Old 03-22-2012, 10:37 AM
dustman dustman is offline
Default in-line fuel filter
Hello, looking for suggestions for an in-line fuel filter for a carbureated engine with AN fitttings. Thanks
Dustman
RV3B
St Marys Georgia
Dues paid 11-11-2011
Old 03-22-2012, 10:43 AM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
I just purchased some, try Summit Racing or JEGS. I had to have those that you can take apart and clean as needed. Very good quality too.
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 03-22-2012, 12:09 PM
Walt's Avatar
Walt Walt is offline
I've been very satisified with Flowezy: http://flowezyfilters.freestarter.com/
I use the 3000 series.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
gasman gasman is offline
http://www.summitracing.com/parts/AE...s/?prefilter=1
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 03-22-2012, 12:19 PM
Tumper's Avatar
Tumper Tumper is offline
Default Midwest Motorsports Inc
Here is what I am using.
I bought two in-line filters at http://www.midwestmotorsportsinc.com.
Search for 4050-06-1. I bought mine in blue to match the other AN fittings. Great quality. The end unscrews and you can clean the filter. Has an o-ring seal.
Dean Eiland
Aubrey, TX
Former Vice President EAA Chapter 1246
RV-9 (yes) N369RV
Mattituck IO-360, C/S Whirl Wind Prop, GRT, Digiflight II, Garmin SL30 & GTX 330 and Hotel Whisky Aux tanks, Bla Bla Bla
Flying
Old 03-22-2012, 01:22 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
I understand that paper or cellulose-based filters should not be used but, other than that, how is the proper micron level determined on filters with the stainless steel screens? (The ones mentioned above range from 10 microns to 100 microns.)
Also, are there generally any requirements regarding where filters can be placed relative to 90-degree elbow fittings, fuel flow transducers, etc? In other words, are they supposed to be used in locations where you have unimpeded straight runs on both the inlet and outlet sides of the filter or does that not generally matter? (Just trying to determine where I might have room for a filter in my system. I have a fuel flow transducer located aft of the firewall that probably should have a filter upstream.)
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 03-22-2012, 01:41 PM
Bevan Bevan is offline
Default Filter size?
The above filter is 10 micron I believe. (there's 25,400 microns to the inch) Isn't 10 microns too fine? What size of contaminant partical can we expect to pass through the carb/fuel injection system without causing a blockage? I would think that we want "minimum" filtration to prevent unnecessary restriction somewhere downstream but also not to impede normal fuel flow at the filter at the available pressure.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 03-22-2012, 01:54 PM
Walt's Avatar
I use a 74 micron, I believe AFP's filter is around 100. Don't forget to look at the important specs like pressure rating, fuel flow, and filtration area. Stainless steel mesh only.
Old 03-22-2012, 02:09 PM
Tumper's Avatar
Default Filter
I guess I should have pointed out that I am using the filters I mentioned as “pre-filters”. I placed these between the tanks and fuel selection. I have an additional filter that is after the fuel selector and before the electric fuel pump. These filters are basically a fine screen intended to catch large particles.
Dean Eiland
Aubrey, TX
RV-9 (yes) N369RV
Flying
Last edited by Tumper : 03-22-2012 at 02:13 PM. Reason: Error in location of filter
Old 03-22-2012, 05:21 PM
Earl's Performance makes some good ones-#230206 for the 85 micron with stainless screens. I think Summit or Jegs has that part #, if not Barnett Performance in Atlanta I know does.
Tom
Ridgeland, SC
