Old 03-22-2012, 04:33 AM
gstone gstone is offline
Default Toggle switches with breakers??
Starting to wire and have heard of but can't seem to find info on switches that include the breaker. Seems this would save some space, trouble and weight if there are not any draw backs????
Any thoughts on this??
Also!! Does anyone know of an insulated terminal firewall fitting to pass thru with a positive cable and leave a terminal inside?
Thanks in advance!
Greg
Old 03-22-2012, 05:29 AM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
Here are the breaker / switches, I use them in my -4, they are great:
http://www.aircraftspruce.com/catalo...rcuitbrkr2.php
I know what you mean for the firewall pass through, and I'm sure that ACS has it, but I can't find it on their site...
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
Old 03-22-2012, 06:20 AM
N427EF N427EF is offline
I used these for battery cables.
http://www.jamestowndistributors.com...11971&type=pla
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Old 03-22-2012, 07:21 AM
William Slaughter's Avatar
William Slaughter William Slaughter is offline
Default Pass throughs
Note that the pass through referenced, while nicely made, is plastic. Opinions vary widely on how much emphasis to place on the "fire" in firewall, but it's a point to consider.
William Slaughter
Houston, TX
RV-8QB
Old 03-22-2012, 10:49 AM
John Clark's Avatar
John Clark John Clark is offline
Originally Posted by gstone View Post
Starting to wire and have heard of but can't seem to find info on switches that include the breaker. Seems this would save some space, trouble and weight if there are not any draw backs???? Greg
Having owned a B55 Beechcraft full of them, I used the toggle switch breakers in my '8' and haven't had any issues. There is an AD out on some that were used in several production airplanes though, so be careful of "good deals" on used breakers.
http://csobeech.com/breaker-switches.html
John Clark ATP, CFI
FAAST Team Representative
EAA Flight Advisor
RV8 N18U "Sunshine"
KSBA
Old 03-22-2012, 10:30 PM
aerhed aerhed is offline
Check out ETA 3120 and 1120 breaker switch series. many options. I ordered mine through Allied Electronics with dimmable LED indicators and color coded for application groups.
Actual repeat offender.
