Old 03-21-2012, 03:51 PM
GEM930 GEM930 is offline
Default Alternator underdrive pulley
I posted to an older thread about this, but realized it was the rv-10 section only. I'm reposting here in hopes that I might get a larger audience. I looking for an underdrive pulley the standard Lester part # 14684 alternator. Any ideas where to find one or suggestions on size???
Thanks guys! (and gals)!
Old 03-21-2012, 04:18 PM
PerfTech's Avatar
PerfTech PerfTech is offline
Are you looking for a larger pulley for the alternator?
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 03-22-2012, 06:33 AM
Yes, Appearently the standard pully the Lester comes with drives the alternator much faster than need be when used with the large lycoming flywheel.
Old 03-22-2012, 07:44 AM
chaskuss chaskuss is offline
Gregg,
One source for a larger alternator pulley [3.25" & 4" diameter are popular] would be your local automotive "hot rod" shop. You need a pulley for a 15mm shaft. You could also check with the popular "mail order" hot rod shops like Summit Racing or Pegasus Auto Parts [owned by RV builder/owner Chris Heitman] See
https://www.pegasusautoracing.com/pr...asp?RecID=5548
Charlie
Old 03-22-2012, 08:34 AM
Walt's Avatar
Walt Walt is offline
Installing a larger pulley will likely require a new belt and may also cause interference with the cowl (I know clearance on the 7 is very close between cowl and pulley).
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 03-22-2012, 08:38 AM
Don Jones's Avatar
Don Jones Don Jones is offline
Default Pulley
I have a 3" (might be 3 1/4") 15 mm shaft pulley. It is at home, so can't measure it. Let me know if you are interested.
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 03-22-2012, 04:13 PM
If its 3.25 I might be, let me know. Also please measure the width of the flat area at the bottom of the "v".
Thx!
Old 03-22-2012, 04:27 PM
Default I installed a stainless steel pad on the cowl
I have the later RV-6A cowl and the standard pulley clears it when it is just sitting in the hangar but I noticesd markings where there had been pulley to cowl contact and knew it was only a matter of time before the cowl was penetrated. I cut off the blade of a SS butter knife and glued it to the inside of the cowl with structural adhesive over the contact marks. Now several years later there is a grove worn in the SS. My neighbor has a slot cut completely through his RV-6A cowl by the alternator pulley. Compared to the airplane, alternators are a throw away part and I would not try to save it at the risk of damaging the cowl.
Bob Axsom
Old 03-22-2012, 07:33 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Bob Axsom
I've seen many a cowl with a little "bump" for the alternator pulley - in fact, I've installed a couple of those bumps. Very simple fiberglass work, and you just put it where the groove tells you to....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 03-22-2012, 08:55 PM
flytoday's Avatar
flytoday flytoday is offline
Default Hidden bump!
And very few people even notice the bump! A tennis ball with wax paper makes a great bump shaper, pressed into the soft fiberglass from inside of the cowling.
flytoday
RV7A - purchased flying 05/2020
RV6A - purchased flying 07/2011
