Hi Jay,
I used a tube of Flamemaster to seal the trailing edges on my empenage control surfaces, and I was barely able to use it all before it began to cure to the point where it was too difficult to squeeze out of the tube.
I used the quart for the tanks. Don't be intimidated by it - as others have posted it's not really that difficult or messy. I also use syringes to measure out by VOLUME, not by weight using the 10:1 ratio. I talked to the manufacturer about that and they said that was fine, just wasting a little hardener. I use a 50cc syringe for the white part, and a 5cc syringe for the black part... very accurate and you can easily measure out small amounts for touch-ups.
This was a VERY useful tool:
http://www.aircraftspruce.com/catalo...ealantgun3.php
I was able to get one on ebay for $30 used. If you decide to buy one get the non-pistol grip gun with a 2.5 oz retainer. Inserts and tips can be used over and over - just let the sealant cure and you can peel it out good as new.
Good luck - let me know if you have any questions.
Tom
