Old 03-20-2012, 07:30 PM
carrollcw's Avatar
carrollcw carrollcw is offline
Angry How did the holes in the ribs get too big?
So, I am assembling the horizontal stab for a -7. I am to the point where it is time to rivet the skin to the ribs. When I went to Cleco the skin to one of the ribs, I noticed the Cleco would not grab the rib! I checked the rest of the ribs, and 4 of them will not hold the Cleco! The holes are not large enough for the next bit size (so I know I didn't drill them wrong) but they are clearly too big for the Cleco and rivet! Also, I dimpled all the ribs at the same time, so its not like the dimpler was set wrong.
So, what do I do? I could Cleco from the rib to the skin (since the skin will hold a Cleco) and go ahead and rivet. Or, I can drill and dimple up one size rivet, but that will be a major PITA!!!
So, 2 questions:
1) What should I do?
2) How did this happen? Did I get some ribs that were predrilled too big? It makes no sense!!!
Thanks!
Clark
Old 03-20-2012, 07:50 PM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
My first thought is it could be your Clecos. There was another thread recently where several builders were complaining about inferior Clecos not holding just as you describe. Try switching your Clecos around or maybe even borrow Clecos from another builder. Hope you find a simple fix.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 03-20-2012, 07:51 PM
Av8torTom's Avatar
Default Pictures?
Some pictures might help. How do the rivets appear to fit in the holes? Have you tried to set any? I'm wondering if your clecos are defective.
Tom
N677AT reserved
Superior XP O-320, 160HP
Old 03-20-2012, 07:56 PM
bret's Avatar
bret bret is offline
just a thought, but did you maybe open up the skin a little too much to dimple, and maybe this is just too much spring back pressure of the skin for the cleco to grab hold, I think mine was like this?
Old 03-20-2012, 08:22 PM
carrollcw's Avatar
I was using a pneumatic squeezer with the same dies and setting for all the ribs. As to the rivets, you can definitely tell there is more wiggle room compared to the standard rivets that I have set. Clecos worked fine before dimpling. I am thinking redrilling to next size is overkill. Leaning towards installing clecos from inside and making it work, but waiting for more responses!
RV-7 Flying Since March 2015
N412HC
Titan IOX-370
SDS Tunable Injectors
EFII Dual Ignition and Fuel Injection
Garmin G3X Touch
Whirl Wind 200RV Prop
7XS0 Polly Ranch Airpark, Friendswood, TX
Old 03-20-2012, 08:24 PM
Cleco little pieces of aluminum properly drilled #40 to back up enlarged holes. Rivet them and forget them. Use proper technique on the next batch.
Old 03-20-2012, 08:26 PM
gstone gstone is offline
Default I'm betting on the clecos also....
I must have ordered the 40 size clecos in two different sets or something because mine are distinctly different. You can hold them up and see the tiny ones that only have a small curve in the tangs versus the better ones that have a larger curve. I have mine seperated into two bins, the small ones work ok on metal that hasn't been dimpled but don't work at all afterward....
Good Luck!
Old 03-20-2012, 08:27 PM
Stalldog Stalldog is offline
Are you positive you used the right die set for the dimples? If drilled right and dimpled with the right die set, looks like about all it could point to is clecos IMHO.
Jim
Lenexa, KS
RV-7A
Old 03-20-2012, 08:48 PM
bird's Avatar
bird bird is offline
Default normal
It is probably normal after dimpling in the really thin skin. You will find that along in the build when you have thicker skins the problem will go away.
bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
Old 03-20-2012, 08:57 PM
rv7boy's Avatar
Forum Peruser
Isn't Friendswood near Houston? I'm sure there are several RV builders near you. Check the RV White pages and contact an experienced builder to come over and offèr an opinion. Even a phone conversation may help you.
P.S. make sure your pneumatic squeezer isn't affecting your die/hole alignment during it's action.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
