Originally Posted by DonFromTX
You get WiFi or cell reception at 4500 feet? I notice that with the sun shining directly on the IPad, it still can be read!
I can get cell reception easy with these.
Wireless wifi / 3g
Fitted with the external 13db antenna. The antenna sits on the back shelf I made, on top of the baggage area.
It was only when I was in the middle of Australia, that I did not have signal.
With the Ipad, I find that I can get 10+ hrs of use, then I need to charge it up again. If the screen brightness was higher, I think I would loose a lot of battery time. As seen in the picture, it still can be read with direct sunlight.
I usually have it sitting on my right leg ( i found the knee dock, not very good )
I was able to read VAF, check/send Emails, and most important to me, look at live weather radar and weather updates.
