Old 03-20-2012, 02:21 PM
walkman's Avatar
walkman walkman is offline
Default Formula to calculate % power
I'm building a little spreadsheet so that I can track performance over time. I want to enter observations such as indicated altitude, airspeed, OAT, rpm and MAP, fuel burn etc and have it calculate density alt, true airspeed, % power etc.
This will help for some planning, but mostly to identify trends over time, potentially catch problems, and will help quantify any performance changes due to any changes I make.
I've got all the calcs except for % power. I have a power setting table but I'm a bit stuck on how I would use that in Excel. I'd really like to find a formula for calculating % power based on density altitude, rpm, and MAP. Any ideas?
This is for an O-360.
RV-8 IO-360 (Bought)
RV-6 O-360 C/S (Sold)
Walkman aka Flame Out
Old 03-20-2012, 03:30 PM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
Default Kevin Horton
Kevin's Website
Look down the left side for "IO-360-A, -C, -D, -J, -K and AIO-360 Power Spreadsheet"
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Old 03-21-2012, 11:10 AM
walkman's Avatar
Thanks. The Kevins sheet for some reason throws all sorts of errors and doesn't work for me.
I think what I'll do is create a separate curve for each RPM in {2000, 2100, 2200, 2300, 2400, 2500, 2600, 2700} for pressure alt vs MP. then use curve fitting to approximate the formula for each.
Old 03-21-2012, 09:11 PM
gtmule gtmule is offline
Search Excel help for "look up tables"...
Old 03-22-2012, 11:41 AM
walkman's Avatar
found an older version that works. go figure. I'll utilize that. thanks for the pointer.
Old 03-22-2012, 11:57 AM
rocketbob's Avatar
control-A, right-click, select Unhide, and you can see how Kevin put this spreadsheet together.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 03-22-2012, 02:08 PM
MauiLvrs's Avatar
MauiLvrs MauiLvrs is offline
(RPM/max RPM) * (MP/Atm P) * Rated HP = HP
(HP / Rated HP) * 100 = % power
Dave & Trina
RV-9A Flying - 330 Hrs. Painted Finishing the interior.
Old 03-22-2012, 03:12 PM
walkman's Avatar
Well that's giving my wildly different results than either the lycoming power setting tables or Kevin's spreadsheet.
Example. 9,000' msl indicated, 30.18 in the window, gives me an absolute atmospheric pressure of 21.6". Running at 2,400 rpm and 21.9 map. Your calculation gives me 90% power whereas the others give me 75%.
Am I missing something?
Old 03-22-2012, 04:06 PM
MauiLvrs's Avatar
atmospheric pressure not corrected for altitude.
Try 30.18
Dave & Trina
Old 03-23-2012, 08:04 AM
walkman's Avatar
Try 30.18
ah gotcha....cheers
