Tiny Bubbles
Just did my fuel flow test today on one tank and noticed a few bubbles. Let me explain...
My tailwheel RV-9 sits at a deck angle of 12.4 degrees. In order to simulate a 20-degree climb angle, I connected some clear tubing to my fuel line where it enters the carb and then raised the tubing 27 inches above the carb before letting it drop down into the empty fuel can. Anyway, b/c I was using clear tubing, I could see the fuel as it flowed into my gas can. Of course, as soon as I turned on the pump I got a lot of big bubbles as the fuel system purged itself of air. However, even as I got close to done pumping the 2 gallons I had put into the tank, I was still seeing a few very tiny bubbles flowing with the fuel. I assumed I must have had a leak somewhere that allowed the pump to pull in air, but everything was dry around all the fittings, from tank to carb. Is it normal for this to be so? If so, where might this air be coming from?
FWIW, I was still getting about 26.8 gph for flow and only need to have 18.25 on my 0-320 to meet the 125% requirement.
Thanks for any thoughts.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
