03-17-2012, 06:46 PM
Rudder skin/stiffener goof
I was back riveting the stiffeners to my rudder skin. I didnt realize the edge of my back riveting plate was not under the rivet. The edge of the back rivet plate was about 1/16" away from the rivet. When I applied pressure to the rivet gun, it pushed the edge of the back plate into the skin and the rivet gun creased the stiffener. I wish the pics were better but the creases are raised about a fingernail's thickness. Is this something that is cosmetic or do I need to order new skin and stiffener?
03-17-2012, 07:52 PM
Blue,
can't really tell from the pics if the skin is cracked, but this can probably be repaired. it's up to you to decide at this point if you will always see this flaw when you look at the rudder or not, but believe me, you will have a lot of these flaws during the total build. Remember, it's an airplane not a watch, some flaws are ok.
03-17-2012, 08:52 PM
stiffner
If it's not cracked it probably will in the future.
03-17-2012, 08:53 PM
repair
Could put a repair there if it's a costly part.
03-17-2012, 09:46 PM
I did the same thing
I did the same thing on the same part and ended up replacing the rudder skin. Skin was about $50, shipping was about $40! I should have just lived with is and filled it when I painted because I ended up damaging the new skin later on in the build with a cleco I that I didn't notice on the work bench.
Jeremy
ATP, CFI, CFII
RV-7 N424JD KCHD
EAA Tech Counselor
2017 Bronze Lindy
03-18-2012, 05:10 AM
I would call Van's Monday,
The stiffner looks like it took the blunt of the damage. I think they will tell you to replace the stiffner, which you can make out of some scrap .025 material. Just bend it over a 2X4 and cut it to shape.
If the skin is not cracked you can probably fill it and get away with it. the stiffner will provide a backing to the skin.
But i would check with Van's and talk about the options first.
Smilin' Jack
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
03-18-2012, 05:23 AM
I sent vans an email yesterday. The skin is almost cracked now and the stiffener did get beat up pretty bad too. Jeremy hit the price, its about $45 for skin and stiffener, so price isn't a repair factor.
03-18-2012, 07:59 AM
I'd replace it....as a matter of fact I did replace my rudder skin several times.
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
03-18-2012, 08:06 AM
replace
Yep, just bought a new skin and stiffener this morning. Upon closer inspection this morning, I could see the aluminum skin was stretched to where it was so close to cracking that I don't know how it didn't crack. It's a repair waiting to happen. Easier to fix now than taking a flying airplane off the line for repair in the future.
Dang it, I was gonna build this whole airplane without a single replacement part....
03-18-2012, 02:44 PM
We all were too! You can guess how that worked out for us
Robert Williams
Lee's Summit, MO
RV-8 - Empennage & Wings Done
Working on Fuse
O-360-A1A
1946 Cessna 120
