Be sure to check the MATCO web site for appropriate maintenance procedures. As I recall, the MATCO nosewheel on the RV-12 (#WHLNW51CC) has a similar bearing configuration. This type of bearing does not need to be greased -- it is a sealed bearing. Also, the manner in which you install / tighten the axle nuts is different depending upon the model number of the wheel. Be sure to check with the manufacturer's manual.
-- David
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 940+ hours (as of September 2020)!
V AF donation through June 2021.
