Old 06-12-2006, 09:04 AM
Paul Eastham's Avatar
Paul Eastham Paul Eastham is offline
Default Backing off pipe threads
Hi group,
Well, I got my engine hung yesterday! Very exciting.
I have a question though: To get some of the angled oil fittings on the engine "clocked" to the proper position, I had to unscrew them just a tiny bit from where the engine builder left them. This involved the oil pressure port and the oil cooler return fitting.
These are pipe-thread fittings, and I've read a few people say that unscrewing pipe fittings may cause leaks -- at least on the brake lines. Torque is still very high (>250in-lbs for a -8 steel fitting).
Given the high torque I don't think tightening them another full revolution is an option.
Thanks for any opinions!
Paul Eastham - Mountain View CA
RV-9A standard build, flying! ~300 hrs
EAA Chapter 338 San Jose
Old 06-12-2006, 09:14 AM
Yukon Yukon is offline
Banned
Default Permatex
I would remove the fittings, clean them, and re-install them to the proper position with non-hardening Permatex (2b).
John
Old 06-12-2006, 10:09 PM
Wicked Stick's Avatar
Wicked Stick Wicked Stick is offline
Can the fitting be "tap n die'd" slightly to change the angle where it tightens ?
I was wondering if it's acceptable to take a die and run it on the threads a little to get it to tighten in a different postion. Is that a normal, acceptable procedure ?
Dave "WS" Rogers
RV-8 N173DR
