Old 03-15-2012, 06:26 PM
N787TR N787TR is offline
Default Best Way to Clean Fuel Pump Filter?
I want to inspect my AirFlow Performance fuel injection filter and was wonder what other people did to minimize spilling fuel in the cockpit... suggestions?
Thanks in advance
Todd Richmond
RV-7A, N787TR
Old 03-16-2012, 08:40 AM
JonJay's Avatar
JonJay JonJay is offline
Turn fuel selector to off. Disconnect main fuel line at servo. Place bucket or provide means to catch fuel. Run boost bump until fuel quits coming out of the line (you will hear the change in the pump as it goes dry).
You can then remove the filter and at the most a drop or two might spill out. Use a rag under the fittings to catch any drips if there are any.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 03-17-2012, 06:59 AM
Rhino889's Avatar
Rhino889 Rhino889 is offline
In the Marines I learned a cool trick when changing fluids on the different trucks.
Disposable Diapers
Cheap and get into places that buckets/jars/etc can not get to.
We changed the oil on a friends RV and wrapped the filter in a Diaper before unscrewing the filter. Not a drop. Also good when you change fluid lines.
Regards,
Scott
VAF DUES 7/13, 12/13, 03/14
Founder/Director
www.Aircraftwraps.com
This is my personal account and does not reflect the official communications of Aircraftwraps.com. We have retained a username for such correspondence. I post about formation, eating, aerobatics and pilot stuff .
