Old 03-15-2012, 06:04 PM
ArVeeNiner's Avatar
Default How to list an experimental engine on the FAA application?
I have what used to be an O-320 B2B. I changed the sump to one that didn't come on a B2B. I now have an experimental engine with no data plate. What do I list this engine as on the FAA application?
O-320 B2B?
O-320 B2B EXP?
O-320 B2B modified?
I sent this question off to the FAA inspector but no response yet. I want to have one of the required forms notorized in the morning.
Thanks.
Kelly Johnson
San Jose, CA
RV-9A
Pink slip issued: 5/7/12
Phase I Complete: 8/18/12!
2020 donation: complete
Old 03-15-2012, 06:10 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
You call it what you want... Unknown works fine too...
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 03-15-2012, 06:51 PM
DanBaier's Avatar
DanBaier DanBaier is offline
Default I think...
If you didn't make a change that just changes the engine to some other version of a Lyc (that has type certificate data), then you truly have a one-off engine of your own making.
Don't use a Lyc data plate. I don't believe that any data plate is required, but you may get some push back from some DARs and the easiest course may be to attach one. Relative to the old data plate - note FAR 45.13.
As to the manufacturer - it's you. The model is whatever you want to call it; although, O-320 is probably not a bad idea. Serial number - it's up to you. HP - up to you; using the same as the O-320-B2B would make sense.
I'm sure there will be other suggestions. YMMV.
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
Old 03-16-2012, 05:18 AM
pierre smith's Avatar
Default Pick a name.
Make it Arvniner 0-320 if you please.
We made ours a Smith/Morgan 0-360 since we majored it and weren't licensed A&P's. DAR was happy.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 03-16-2012, 05:33 AM
miyu1975's Avatar
miyu1975 miyu1975 is offline
I had the same question sort of...I have, or had, a IO 360 A1A certified lycoming, it now has dual pmags. Does the pmags now make this an experimental and if so do I have to remove the lycoming data plate and make up my own?
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
Old 03-16-2012, 10:18 AM
aerhed aerhed is offline
That's actually a good question. If you've done nothing else and you unbolt the P-mags, then yes it is an IO-360-A1A with no ignition installed. With the P-mags installed it no longer conforms to the TC. The approved magnetos are called out in the TC, as are spark plugs. I've never seen anyone MAKE you remove a dataplate from a similar engine. Do AD's apply? Consult your magic 8 ball.
Actual repeat offender.
Old 03-16-2012, 01:03 PM
turbo's Avatar
turbo turbo is offline
not sure if this helps but, my experimental from lycoming thunderbolt has a serial # of EL-41036-36E. model o-360-EXP make lycoming. that is off the certificate.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 03-16-2012, 01:29 PM
jdeas's Avatar
jdeas jdeas is offline
Default Fom 337
How about O-320 Clone? I did the same thing and was planing to send in a form 337. That would allow me to get Lycoming to supply a new data plate.
IO-360-B1E to IO-360B1B
The possible issue is some documents say you can not turn in a 337 until the unit is installed in an airworthy airframe. Kind of the chicken/Egg situation for a new aircraft
I plan to use 'clone' then worry about the 337 and data plate later
JD
RV-7 N314SY (KWHP)
IO-360-B1B
CANbus based trim/flaps and electrical
Old 03-16-2012, 02:10 PM
badmrb badmrb is offline
Default 337 form?
Experimentals dont require a 337 form.
Also, I have heard of folks being required to remove the engine data plate stating it was a Lycoming "so and so" for the very reason it couldn't be used again on a Type certified aircraft. The inspectors required it at the time of inspection and issuing an airworthiness cert.
