Old 03-14-2012, 08:49 PM
Tailpilot Tailpilot is offline
Default Roiling trailing edge of horozontal stab
Has anyone tried to use an edge roller on the trailing edge of the horozontal stab. Didn't know if this would interfere with the elevators. I thought about rolling the edge for a cleaner look.
Old 03-15-2012, 12:11 AM
bird's Avatar
bird bird is offline
Default elevator
Any closure of this area may restrict the space necessary to get design elevator travel. Mine is built as per plans and with full design deflection, the elevators are very close to the aft stabilizer skin.
bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
