Old 03-12-2012, 04:50 PM
bruceh's Avatar
bruceh bruceh is offline
Default Best location for auxiliary power ports?
I bought 2 of the 12V cigarette lighter type power ports. Just wondering what the collective wisdom of this forum is before I start drilling holes to mount them.
Panel?
Baggage area?
Down between the seats somewhere?
One or more of the above?
In most cars they are in the center console down low or between the seats/armrest. It looks like I can get one or both of these down on the little doghouse housing cover for the fuel injection pump/filter. My particular installation there has sufficient clearance around the plumbing, but I'm not sure this is a good location due to the potential for making sparks.
Bruce Hill
2020 VAF donator
Old 03-12-2012, 05:08 PM
Mel's Avatar
Mel Mel is offline
I mounted one on the bottom of the panel that is forward of the instrument panel. It's out of the way, reachable and doesn't take up panel space.
Mine is tied directly to the battery so I can plug in my battery maintainer.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 03-12-2012, 05:25 PM
N941WR's Avatar
N941WR N941WR is offline
Mine are located in the lower right side of the panel because they are not needed for flight.
One of them is wired to the always hot buss with heavy wire and protected by a 7.5A breaker. That allows me to charge the battery through it. The second one is on the avionics master.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 03-12-2012, 05:34 PM
dlloyd3's Avatar
dlloyd3 dlloyd3 is offline
Default Aux power port
Could not make up my mind where to drill the panel so it went at the bottom of the sub panel. Out of sight but can still reach it in flight.
Dave
M20C
Old 03-12-2012, 05:51 PM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Passenger seat arm rests.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-12-2012, 06:06 PM
Lars Lars is offline
Lower right side of panel, wired like Bill R's.
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
