  #21
Old 03-13-2012, 08:35 PM
rvbuilder2002's Avatar
Default Another vantage point....
I have a lot of cross country flight time in 3 different RV-12's (some of it on trips of 1800+ miles).
I use the site window to verify fuel levels in comparison to the electronic fuel gauge and fuel computer, before and after a flight.
After some experience, it is easy to guess within a gallon or so, what the fuel level in the tank is based on what the level is in the site window.
I have never splashed fuel on me when refueling.
It is easy to recognize by sound when it is getting nearly full without having a gauge to look at. The only time it has been challenging is if a fuel truck is parked very close and is overly loud (only happened once or twice).
I am not meaning to put down anyone that chooses to install a mechanical gauge, but I do think it is a higher level of risk to rely on a mechanical device to confirm a fuel level before flight. (And I do kind of wonder when someone blocks off the site window, installs a mechanical gauge, and then uses a dip stick to verfy the fuel level...... kind of seems like a step in the wrong direction)
It has been a long time standard to use your eyeball and visually verify a fuel level before flight.
That is the entire engineering basis for the site window... walk up to the left side of the airplane... jiggle the wing while you look at the window... verify that the fuel level is above the 4 gal. minimum fuel for take-off limit... go fly!
Old 03-13-2012, 10:32 PM
tim walter tim walter is offline
Default collapsible gas can
like this?
http://safetycentral.com/gasohaul.html
Tim Walter
KDVO
http://rv-12-tim-walter.blogspot.com
kit# 120528
Old 03-13-2012, 11:03 PM
Bill_H's Avatar
Bill_H Bill_H is offline
One gallon? What's the point? I'm going to get low on fuel, land off-airport somewhere, put in one gallon, and continue? Don't think so! Maybe for a car if you have - say - a spouse that likes to crowd EMPTY - but not a plane!
Old 03-14-2012, 06:28 AM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
Pretty pricey for a one time use disposable gallon can too.
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 03-14-2012, 09:46 AM
DHeal DHeal is offline
As I recall, these portable bladder tanks have been displayed at OSH: http://www.turtlepac.com/
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 940+ hours (as of September 2020)!
VAF donation through June 2021.
