  #11
Old 03-13-2012, 11:55 AM
Sam Buchanan's Avatar
been here awhile
Originally Posted by Adam View Post
Thanks Mahlon, I just wonder what the week link is when there is a failure, builder, maintnice, parts or all the above? I guess I'm asking what is the best way to be proactive to ensure a reliable engine!
Purchase your engine from a vendor that has a proven track record in the RV community. Keep it maintained to a high level and you should have many great years of flying.
Sam Buchanan
RV-6
Fokker D.VII replica
Walt's Avatar
Walt Walt is offline
My 2c for best longevity:
Change the oil every 25 hours!
Run 65% power or less.
Lean aggressively (65% power or less).
Keep it cool.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 03-14-2012, 12:20 AM
frankh's Avatar
frankh frankh is offline
build or buy a crankcase dehumidifier and get the steam out of the case by hooking it up before the engine cools.
No moisture inside crankcase equals no rust...I can't prove this stops corrosion but i can prove the case is full of steam after flight and the dehumidifier will get it out.
for $40 bucks in parts it has to be valuable insurance.
Frank
Old 03-14-2012, 01:09 AM
Ironflight's Avatar
VAF Moderator / Line Boy
One other way to keep the corrosion/moisture problem to a minimum is to fly the airplane regularly - like several times a week. If that's your plan, you're on your way to long (engine) life.....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 03-14-2012, 01:32 AM
frankh's Avatar
Absolutely..Now if only I could find such a wonderful work/life balance..
Frank
Old 03-14-2012, 04:58 AM
pierre smith's Avatar
Default Maybe.
You're in luck, Frank!
I fly for a living and don't look forward to my occasional RV flight as much, because of that....sadly. My living is in the air.
You guys that have the weekend trip to look forward to, really have a much broader sense of appreciation for those rare times than I do.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 03-14-2012, 07:08 AM
Jerry Wilcox's Avatar
Jerry Wilcox Jerry Wilcox is offline
Default engine reliability
Not sure if this will be on track re the original question. When I got out of high school I went straight to work with an auto engine rebuilder, started doing cylinder heads then boring blocks and into actual engine building. Also a bit later had a motorcycle shop and then got into aircraft maintenance. No mention has been made of the guy driving the thing. I have done lots of engines over the years from single to 12 cylinder and know that you can use the best stuff available but if the guy running it want's to he can always break it. You probably realise I'm aiming that statement at the car motorcycle side of the equation. Airplane engines are high performance engines (car guy's are probably laughing now) and deserve treatment as such. I say that because any engine that will put out it's design HP or 75% of that for it's life, in this case 2000hrs, is definitely high performance. Big auto engines might do 15 - 30% of their rating continuous. So know you engine how to run it properly and do as others have said maintenance wise and you will have a great flying experience.
I should also add that I prefer genuine Lycoming parts but have used Superior and had good service. Am not a fan of the ceramic coatings and other gimmicks that are always going to revolutionize the industry. I like to keep it simple.
Jerry
Old 03-14-2012, 09:23 AM
Keep it cool.
AMEN to that.
It is a formula that works and if the engine is assembled with care by someone who knows his stuff, it will last a long time.
I like BPE.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 03-14-2012, 12:36 PM
Adam Adam is offline
Thanks Jerry, good information!
Adam Silverstein
Technical Counselor Chapter 643
Flying RV-8 10/30/07
PAID 2021
Pittstown, New Jersey
Old 03-15-2012, 07:16 AM
G3i Ignition's Avatar
G3i Ignition G3i Ignition is offline
A few years ago I spoke with a tech rep. from Shell Oil Company about internal corrosion. He stated that depending on what part of the country you reside in, the moisture/ condensation that accurse in the engine after shut down will require that the next flight have a minimum of 18 minutes of operation @ 180 degrees oil temp or above to remove all previous existing moisture. Another thought of mine, is I do not move the prop around by hand after shut down or pre start-up. For this removes the oil film that was left behind on all mating parts. This is required for lubrication on the next start up. Turning an engine over by hand or just cranking on a starter to lube things up before start-up is a no, no. Just light the engine.
Thomas
Thomas Shpakow
http://www.G3ignition.com
Follow G3i on Facebook.
www.facebook.com/pages/G3i-Ignition/243104229291
