Old 03-10-2012, 05:50 PM
Mark L Mark L is offline
Default Wider hinge for improved aileron/flaps alignment
Could someone provide the wider flap hinge, part number from Aircraft Spruce (I beleive it to be an AN257-P4, but can't determine the actual part #) to replace the stock -p3 hinge on the wing in order to get the proper rivet edge distance between the aileron and flap
Mark Lancaster
RV-7A N530L Finish Kit
Old 03-10-2012, 05:58 PM
DaAV8R DaAV8R is offline
Default Hinge
I believe it is MS20257P4-6
If I remember correctly the P3 is 1.25 wide and the P4 is 1.5.
Robert Williams
Lee's Summit, MO
RV-8 - Empennage & Wings Done
Working on Fuse
O-360-A1A
1946 Cessna 120
Old 03-10-2012, 08:09 PM
GAHco's Avatar
GAHco GAHco is offline
Smile Hinge Info!
See Rolled Hinges
http://www.gen-aircraft-hardware.com...df/ms20257.pdf
See Extruded Structural Hinges
http://www.gen-aircraft-hardware.com...df/ms20001.pdf
I hope this helps!
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
