03-10-2012, 02:49 PM
Shop heads not forming fast enough
Scott Balmos - RV-9A N112SB
Cincinnati, OH, KHAO
03-10-2012, 02:51 PM
you should be using the -4 diameter gauge, not -6! that's the length
03-10-2012, 02:52 PM
That -6 is for a -6 size rivet where yours are 4-6's, the 6 in your rivet number is the length not the diameter..... You need to use the 4 size hole...
Clear as mud....
03-10-2012, 02:57 PM
That's what I thought after a few minutes. Kept staring at the -6 hole and thinking "there's no way it can be that wide. That'd be overdriven!".
Yeah, no kidding gstone. It's the dash that throws us new kids off who are still new to rivet specs. The -6 for the length makes sense. But then you see the -6 for the hole, and nothing in Cleaveland's instructions says you should really be matching with the first number after the AD, which matches the diameter.
Or maybe I was just being dense, since they were the first rivets. :/
Okay, so actually the shop heads are fine then. Should I worry about the dents on the manufactured heads?
Reason: removed expletive
03-10-2012, 03:13 PM
If you're talking about the last picture. YES. Surely there is someone within a half hour drive that can show you 10min worth of basic riveting?
Scott Card
CMW E-Lift
03-10-2012, 03:31 PM
I would suggest that you not drill them out until an experienced friend can come out and help you with your technique. Initially, if you can find someone who is experienced and work with them for a 100 rivets or so with one of you driving and the other bucking, you will learn quite a bit and it will prepare you for doing the deed on your own. Don't sweat it, you'll get the swing of it!
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
03-10-2012, 03:53 PM
Like the others are saying. Stop and get some help.
You are gonna need to address those scratches on the spar bars as well.
30 minutes with someone that knows how will get you going correctly.
03-10-2012, 04:31 PM
Scott - get plugged into this group
http://groups.yahoo.com/group/OhioValleyRVators/
Hi Scott. Saw you are close to Cinci. My advice to you is to join this group. RV gods galore belong to said mystical tribe....
Seriously though, there are some really good people with tons of skill that communicate through the Ohio Valley RVator group. Info on tools, techniques, other projects in your area, Fly out gatherings, etc. is there.
Built 7A flew 700+ hrs - sold
- 7 flying
03-10-2012, 07:36 PM
Scott,
I'm still learning and far from a pro, but I live in Goshen. If you'd like, we could get together and maybe, just maybe, I can help you out. I'm currently working on the wings for an RV-7. Let me know if you're interested.
Brad
Brad Maxwell
RV-7 standard wing slowly being built (Wish I had more time!)
Cincinnati area (Goshen)
03-10-2012, 09:02 PM
I'm running my 3x at 40psi using the standard bucking bar that comes with Avery's rivet gun toolkit. Any tips?
On 470 rivets I am running my 3x rivet gun at 60psi. A quick trigger pull and they are set.
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
SOLD?but I'll be back
