Old 03-09-2012, 09:29 AM
s24789 s24789 is offline
Question KT-76a Dimming
We have a KT-76a that I did not wire to lite the digits. My question is does the 76a have an auto dim feature ? I am asking because when I put my hand over an openIng in the face as currently wired, the reply light dims. If this is correct I could just add a ground to pin 3 and supply 14 v to pin 2. Any smart avionics guys, please comment.
Phelps
Kevin Phelps
Paid thru Dec 2020
RV-7A flying N782WP
Stuart, Fl
Old 03-09-2012, 10:11 AM
Walt's Avatar
Walt Walt is offline
Yes the KT76A has auto reply light dimming and yes you can use you 14v dimmer on pin 2 with pin 3 grounded.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 03-09-2012, 10:55 AM
Thx Walt
Phelps
Kevin Phelps
Paid thru Dec 2020
RV-7A flying N782WP
Stuart, Fl
Old 03-09-2012, 02:50 PM
pilot2512 pilot2512 is offline
The reply light has a photocell for auto dimming. The pins you reference are for the lights behind the digits which do not auto dim, they are designed to be hooked up to a dimmer.
Jay
RV-9A
Empennage complete.
Wings complete.
Fuselage in progress
Wiring in progress
2020 Donation made!
