  #21
Old 03-11-2012, 08:08 AM
rocketbob's Avatar
It it didn't shatter (which they do, even in aluminum) then since its likely a two flute tap at least 50% of the threads remain which would hold a screw just fine, especially considering the light load of the canopy glass.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 03-11-2012, 08:44 AM
Azemon's Avatar
Azemon Azemon is offline
I have been a machinist for over 25 years and would indeed try to use a tap extractor first. But it must be done very carefully. I own and have used several
times a Hansvedt EDM or Spark Eroder. They are absolutely the best way to
remove broken taps as they do not damage the treads. Good luck.
Andy Jones
Another beautiful day in paradise....N2977T
Old 03-11-2012, 09:35 AM
LeeM_2000's Avatar
LeeM_2000 LeeM_2000 is offline
I had to have a broken tap removed from a motorcycle cylinder head a couple of years ago. The EDM worked very well. After that experience, I wouldn't even mess with trying to remove it myself. Now, I would just take it to a machine shop that has an EDM.
RV-7
In progress...
