Originally Posted by osxuser
...you can tweak the idle mixture down a bit 10-25RPM rise is sufficent in FI engines.
Best advice I've heard so far...and it is exactly why the popping occurs. You're running idle mixture at 2000 or so RPM (throttle to idle while the plane is still flying).
Three things...
1) I run a leaner idle mixture than most folks. Stephen's 10-25 RPM rise is exactly what I see (I see 20 RPM). No more. I don't want any more of a rise than that.
2) When you pull your throttle back to idle, do it slowly. That will help.
3) My mixture knob almost never hits the full rich stop. I mean once in a blue moon. This goes against what we were taught back when we learned to fly. Full rich mixture? In normal circumstances, why would you ever flood the engine like that? (I'm speaking strictly about fuel injected engines.) I lean for the conditions in all phases of flight.
