Old 03-06-2012, 05:07 PM
HighSchoolBuilders HighSchoolBuilders is offline
Default Cracked Dimple Repair.... 3/32" hole became 7/32"
Hi guys,
Today I tried to repair a cracked dimple in the F-811 Bulkhead, but end up enlarge the hole to a size 7/32 before all the cracks are gone.
Do you guys have a better way to fix these cracks? Luckily, I don't get these often, but when i do, it's almost certain an oops rivet or even 5/32" will be used.
For this particular boo boo, Can I use a AN4 bolt to fill in that hole? Or should I leave it open and fill it with some sealant or something?
Thanks!
Hank
Photo 1: Damaged/Cracked 3/32 hole on the bottom forward flange of F-811 Bulkhead. enlarged to 5/32 and still cracked
Photo 2: Same Hole on the F-828, not damaged, but enlarge as I tried to fit a larger rivet in.
Photo 3: Hole on F-811 after repair, now at 7/32
Photo 4: Hole in question
Hank Cheng
RV8 Super Slow Build Kit
Titan IOX360, Catto 3 Blades RV prop, Full Dynon everything + Garmin GTN650
First RV in Hong Kong
First Homebuilt aircraft registered in Hong Kong "B-KOO"
Completed RTW journey in 2016
Built with a group of High School Students
Aircraft donated to the Hong Kong Science Museum
In memory of Michael Tam
Old 03-06-2012, 07:08 PM
GAHco's Avatar
GAHco GAHco is offline
Thumbs up Put a structural screw in it!
You could put an AN525-10R8 in the hole when you assemble it.
An aluminum washer under the nut would protect the structure.
It looks like you have plenty of edge distance.
The head should be to the outside.
If you wanted a little higher tech you could use a Hi-lok but I think that would be over-kill.
Best Wishes for your success!
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 03-07-2012, 06:29 PM
chaskuss chaskuss is offline
Hank,
Providing that the issue is "only" on the flange of the bulkhead, my suggestion is that you cut off the horizontal portion of the offending flange. Bend up an L shaped "scab" flange to replace the bad portion. A "scab" flange is commonly used to repair certified aircraft with a problem like this. One portion of the L is positioned against the rivet hole in the skin. The other portion lies flat against the web of the bulkhead and is riveted to the bulkhead. I had to use a number of "scab" flanges on my HS and wing main ribs, due to less than perfect manufacture of these items on my project. I have supplied a few photos, if the written description leaves you scratching your head.
For your situation, a simple L shape made from 2024-T3 of the same thickness as the bulkhead will suffice.
Charlie
Old 03-07-2012, 07:36 PM
TINBENDER TINBENDER is offline
Originally Posted by HighSchoolBuilders View Post
Hi guys,
Thanks!
Hank
Like Tom said, a Hi-Lok prob. would be overkill, but I would def use one over an AN525 panhead. I would recommend an HL18-8, prob. a 3 or 4 in length. You can go with an HL600 collar or an HL70 collar. Hope this helps!
PHILIP RAPPA
PMR AIRCRAFT
JETAVIATION ST. LOUIS
A&P TECH
Old 03-08-2012, 12:16 AM
Thanks for all the suggestions.
Charlie, I have a couple of those in my wing and HS as well, so I know exactly what you are talking about and did consider doing that...unfortunately, the backside of that bulkhead is the tailwheel spring mount, which I prefer not to drill thru it. Thanks for the photos and idea!
I never use a Hi-Lok, but I will look into it. The screw seems like an easy fix too....it's nice to have options.
Thanks again!
Hank
Hank Cheng
Old 03-08-2012, 11:16 AM
JonJay's Avatar
JonJay JonJay is offline
This may not be popular, but I would have done nothing and moved on. The odds of that crack in an .025 skin propogating is minimal in my opinion.
In regard to the repair, I am sure it is fine, however, it appears to violate the edge distance requrements to the flange bend.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
