Old 03-06-2012, 04:37 PM
Question Strange leak what is it?
It is not fuel. I opened the covers and checked with mirror. It's not oil too far from the engine. It's not brake fluid all connections checked. Tubes inspected inside, penetrating AN fitting clean fluid level normal.
The spot looks sticky and greasy. Doesn't smell. I didn't taste it
This is how it looks. What is it?
Old 03-06-2012, 04:45 PM
tkatc's Avatar
tkatc tkatc is offline
Maybe the grease or lubricant you used to persuade your wing spar bolts into place?
Track my RV7A!!
Bought my flying -7A
Building an -8! (Fuse)
jthocker's Avatar
jthocker jthocker is offline
Maybe fiberglass/aluminum chafe residue mixed with water?
I see it all the time.
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Old 03-06-2012, 05:02 PM
Unlikely. Why it showed up in the middle of brutal winter and not in July heat of Phase One?
Interesting. A flight was performed not so long ago in pouring rain. Maybe water got inside and washed that chafe
Old 03-06-2012, 05:15 PM
AlexPeterson's Avatar
Looks like tire dust mixed with something. Maybe rain? Does it rub off readily?
Alex Peterson
RV6A N66AP 1750+ hours
KADC, Wadena, MN
Old 03-06-2012, 05:20 PM
Bruce's Avatar
Bruce Bruce is offline
Brake dust.
I have the same thing on mine.
Bruce (BOOMER) Pauley
Kathy (KAT) Pauley
RV 7A--"MISS MARIE"--- N177WD (SOLD FLYING)72742
VAF #582-----------------EAA LIFETIME MEMBER
EX -KC-135A -------------BOOM OPERATOR #3633
VAN'S FLIGHT------------#6930
RETIRED————————-Enjoying life
See you in OSHKOSH
http://www.mykitlog.com/users/index....ley&project=84
=VAF= 2006-2021 DUES PAID
Old 03-06-2012, 05:28 PM
PerfTech's Avatar
PerfTech PerfTech is offline
Default Me too!!!!
...Tire and brake dust that travels up the fairing. I filled them up with expanding foam, stopped this from forming and also stopped most of the 9-A whistle people talk about. Regards, Allan
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 03-06-2012, 05:47 PM
Bavafa Bavafa is offline
Or could it be brake fluid leaking and collecting dust/dirt?
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - in progress
Dues paid
Old 03-06-2012, 05:56 PM
tkatc's Avatar
YEP!! My vote is brake dust!
Track my RV7A!!
Old 03-07-2012, 05:45 AM
jimbower jimbower is offline
I like the brake dust theory. I flew my -6A without wheel pants and leg fairings for a while, then bowed to peer pressure and installed them over Christmas. Every landing is accompanied by a short burst of tire smoke smell from the landing. It took me a little while to figure out that the smoke was traveling up the fairing and into the cockpit. I just plan to use some aluminum tape to close up the gap around the main gear legs and see if that works. I don't know if I want to foam inside the leg fairings...I might need to take them off someday.
Jim Bower
St. Louis
RV-6A N143DJ
Flying since August!
