Intermittent fuel flow from previously reliable system
I've got a fuel injected IO-360 (parallel) valve with a Red Cube transducer between the servo and the spider. My engine monitor is in my AFS 3500.
For the first 3 years, 350 hours my fuel flow readings have been spot on. For the last couple of months, my fuel flow reading will occasionally drop to zero. The engine runs fine, so I'm pretty sure it is an erroneous reading. To me it does not act like an electrical problem with the transducer, since turning on the boost pump and/or switching tanks usually solves the problem. Any ideas?
Guy
