03-05-2012, 01:21 PM
What happens if you leak Bear Spray on it?
Actual repeat offender.
03-05-2012, 01:47 PM
Originally Posted by John Clark
It isn't fire that is the start of the problem it is heat creating a very flammable gas. I realize that it is a long shot, but why take the chance?
I guess we should avoid painting the interior, since polyurethane paint would be no less flammable!
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
03-05-2012, 01:59 PM
the bed liner coating will weigh more than the material its covering
03-05-2012, 03:23 PM
Baggage area
A light coat of " Rocker Panel Chipguard " will give it some texture and then top coat it with the same paint as your interior.
04-18-2012, 07:28 PM
The standard truck bed liners that are sprayed on, are sprayed on with considerable heat. And that's after the installers scuff the heck out of the metal.
The process isn't something I'd subject my plane to.
Dave
04-18-2012, 07:55 PM
Location: McMinnville, Oregon: HOME of the SPRUCE GOOSE
Cargo area
Depending, the truck bed liner could be applied to deck while cargo deck is out.
Tailwinds...
Simplicity is the ultimate sophistication.
Leonardo Da Vinci
Working on a RV-4
Citabria 7GCBC
Cessna 180
RV7 I0-360 C/S, Slider, AP, Glass, etc. sold.
RV6 O-320 F/P, Slider, AP, Steam, etc., sold
Citabria 7KCAB rental
Piper Cherokee, sold
Sparrowhawk, sold
Proud -VAF- Supporter - Exempt, Dues Paid Anyway.
04-18-2012, 10:54 PM
Have you considered the ray Allen wing walk material? It has a nice scuff distance and you can just cut and stick. Non abrasive too.
I was going to do this and even I bought a roll. But ended up using carpet instead.
Michael Delpier
RV6A -O-320, fixed pitch, GRT Sport, 496
RV-10 - working on finish kit
Houston
04-19-2012, 11:38 AM
Cargo area
It is just hard to beat using a non flamible carpet secured to the luggage deck. It provides some sound, cushion and abrasion protection. It is also easially secured or removed. Hard to beat it.
Tailwinds...
Leonardo Da Vinci
Working on a RV-4
Citabria 7GCBC
Cessna 180
Sparrowhawk, sold
04-19-2012, 12:14 PM
A nice coat of gray Dupont single stage worked as my entire interior
Lightweight, quicker to install, less to burn, easy to clean or repair and cheaper.
Good judgment comes from experience, and a lot of that comes from bad judgment.
04-19-2012, 06:22 PM
Try this .
Try This Stuff. It is not very heavy, very durable and looks great. I have it in my Fwd and aft Baggage area:
http://www.eastwood.com/media/catalo...p/9/p966_1.jpg
Al "Nordo" Grajek
repeat offender
\___(0)___/
RV8
RV8A
RV8
RV6A
Now RV7A!!
