03-04-2012, 06:10 PM
Are abbreviations acceptable
when labeling the switches and controls on the panel.
For Example
SWITCHES
| ALT | BAT | AVI | LND | STB | NAV | PUMP | CBN | PNL | CP-DSC |
cONTROLS
|THRTL | MIX | CRB | CBN.
Ryan
N123RB RV-9A. ECI OX-340, Catto 3 blade prop, Vpx, Dual Dynon SV. Flying 200 hours. Can't stop smiling.
03-04-2012, 06:13 PM
Senior Curmudgeon
I did some of them that way, my inspector was fine with them.
My suggestion would be to ask whoever you plan to have do the inspection.
Good luck, sounds like it is getting close
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
03-04-2012, 06:38 PM
The FAA words for certification are -
(b) Be labeled as to its identification, function, or operating limitations, or any applicable combination of these factors;...
Sounds like clear abbreviations are OK...
I think they also want direction labeled (the function bit above), such as "Push for ON" and ON/OFF for switches.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
03-04-2012, 06:50 PM
"Obvious" abbreviations are fine.
Several of yours aren't obvious to me.
What is AVI?
If STB is "strobe", it should be at least "STRB LT".
NAV should be at least "NAV LT".
PUMP should be at least "FUEL PUMP" or "BOOST PUMP".
CBN & PNL...are these lights?
You need to be a little more specific.
Whatever you use should be, at a minimum, obvious to anyone reading this forum.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
03-04-2012, 08:22 PM
Originally Posted by rblackley
| AVI | STB | NAV | PUMP | CBN | PNL | CP-DSC |
| CRB | CBN.
I'm positing myself as a generic potential pilot who's climbed into the plane and tried to see what I could about it. These are the ones that I didn't understand right off.
STB probably means standby, but what? And if it means starboard, again, what?
NAV refers to which system?
PUMP probably refers to the fuel pump or less likely the oil pump, but if it's an annunciator light it might be either. And if it were on a Globe Swift it could also be the hydraulic system, and refer to both the landing gear and the flaps.
The others are more obscure, at least for me.
Also, I'd prefer fewer acronyms and would accept smaller fonts to achieve that. But that's just me. You've probably already realized that I tend to be more wordy than necessary.
Dave
03-04-2012, 11:17 PM
Location: McMinnville, Oregon: HOME of the SPRUCE GOOSE
Abbreviations
My aircraft passed inspection with abbreviations labeled. I used only standard abbreviations. You should be OK.
Tailwinds...
Simplicity is the ultimate sophistication.
Leonardo Da Vinci
Working on a RV-4
Citabria 7GCBC
Cessna 180
RV7 I0-360 C/S, Slider, AP, Glass, etc. sold.
RV6 O-320 F/P, Slider, AP, Steam, etc., sold
Citabria 7KCAB rental
Piper Cherokee, sold
Sparrowhawk, sold
Proud -VAF- Supporter - Exempt, Dues Paid Anyway.
