Old 03-04-2012, 03:36 PM
longranger's Avatar
Default Elevator Trailing Edge Crack
I made my initial trim tab opening bend about 1/8" or so too far outboard, and in the process of "unbending" I inadvertently flattened the trailing edge. I opened it back up with my bending block, but now there's about a 3/8" crack along the trailing edge.
Make a "drain hole" at the end of the crack or order a new skin?
RV-7 TU 904KM (reserved)
Construction Log
Old 03-04-2012, 08:17 PM
LeeM_2000's Avatar
LeeM_2000 LeeM_2000 is offline
I wonder if there is a reason you couldn't stop drill it and then fill it with a tiny dab of JB or flocks.
RV-7
In progress...
