Old 03-04-2012, 05:45 AM
s24789 s24789 is offline
Unhappy Replacing Gear Leg on 7A
OK big screw up on the installation of the gear legs on our -7A. We noticed that the tires were REALLY wearing on the outsides. Consulted the forum, and found that this is somewhat common. Then looked over the plans (checked twice during build) and found that there is in fact a left nad right gear leg. We knew it. I guess the paper sticker came off or we are ignorant when installing the brakes and wheels.
Anyway we have convinced ourselves the we have considerable toe-in due to the gear leg switch. We have flown and now need to correct the problem. Looking for advice about jacking aircraft high enough to facilitate the swapping of gear legs. We have the standard Harbor Freight ram jacks but I do not think they will get the wing high enough. Anyone else been as dumb as us and how did you correct it ?
phelps
Kevin Phelps
Paid thru Dec 2020
RV-7A flying N782WP
Stuart, Fl
Old 03-04-2012, 06:41 AM
tkatc's Avatar
tkatc tkatc is offline
First of all, I hope you are wrong about the legs but it sounds like you have done your homework.
Second, I am not sure how high you have to be to remove the gear legs but the HB jacks can get it lifted fairly high.
Track my RV7A!!
Bought my flying -7A
Building an -8! (Fuse)
Old 03-04-2012, 09:55 AM
Bruce's Avatar
Bruce Bruce is offline
Kevin,
I am with TKATC.
I don't think you have a problem with the gear leg.
I know there is a left and right. I think they are the same.
I have the same issue with my left side. Tire wear on the
outside and the right is fine.
I am now rotating them at 40 landings to help the left side
wear out. Also running at 40 PSI. It does pull to left when
tire pressure is not maintained at 40.
The only way to fix the problem is to heat it up and bend it.
Which I am not going to do.
Also you can't shim the 7A gear legs because they are round
vs the 8 that are flat.
I hope this helps.
Did look at DWG 34A
My .05
Bruce (BOOMER) Pauley
Kathy (KAT) Pauley
RV 7A--"MISS MARIE"--- N177WD (SOLD FLYING)72742
VAF #582-----------------EAA LIFETIME MEMBER
EX -KC-135A -------------BOOM OPERATOR #3633
VAN'S FLIGHT------------#6930
See you in OSHKOSH
http://www.mykitlog.com/users/index....ley&project=84
=VAF= 2006-2020 DUES PAID
Old 03-04-2012, 04:35 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Left = U-701A-L
Right = U-701A-R
Most (A) models have outside tire wear over a period of time.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 03-04-2012, 05:18 PM
roee roee is offline
Kevin,
I seriously doubt that you switched the left and right gear legs. Yes, the left and right gear legs are different from each other (mirror image). And the geometry is such that if you swapped them you'd end up with ridiculously wrong gear geometry. It wouldn't go unnoticed.
Some outside wear on the tires is to be expected, simply as a result of the gear geometry as it was designed.
Furthermore, it seems that some RV's experience greater uneven tire wear than others, likely due to variation in the gear geometry within tolerance. On mine I found some measurable difference in toe between left and right. My right main has 0 deg toe (this is nominal), and my left has 1.3 deg toe-in. Discussed this with Van's, and they indicated that the bend in the gear leg has a specified tolerance of +/-2 deg, so it's within spec, and nothing can be done about it anyway short of drastic measures (either replacing or re-bending and re-heat treating the gear leg).
Kevin, have you actually measured how much toe-in you have? I suggest doing that and getting a better assessment of your situation before you start taking parts off the airplane.
-Roee
Roee Kalinsky
San Diego, CA, U.S.A.
RV-7A under construction
www.kalinskyconsulting.com/rvproj/
Old 03-04-2012, 05:55 PM
DanBaier's Avatar
DanBaier DanBaier is offline
Default Tires make a difference too
My first flying was done with the main gear tires that came in the kit. It wasn't long before the outside wear was noticeably more than the inside and it was time to disassemble and flip the tire on the wheel. As it was, the new outside wore down fairly quickly.
For the next set of tires, I went with Desser monster retreads - these are a brute of a tire. After about as much flying on these as I got out of the first set, I can't see a difference inside to outside - no need to flip the tire yet.
One thing - these might be slightly larger than the kit tire - if you still can, leave some room.
FWIW.
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
Old 03-05-2012, 01:00 AM
NickAir's Avatar
NickAir NickAir is offline
Location: McMinnville, Oregon: HOME of the SPRUCE GOOSE
Default Lift clearance
I also hope you are not reversed L & R. Check your current toe in for proper spec + or - 2 deg., as mentioned.
If you do need to lift your RV to remove legs, option as follows:
Build up the needed height with cribbage, (short lumber) to place your regular wing jack on.
Next, build a ramp with 8 foot long (2x6's) for your main wheels to rise to the same level as the cribbage stacked to place the jacks on.
Once the plane is at its position to be jacked, then proceed to jack the plane until the tires are off the cribbage. At this point you just remove the cribbage under the tires and you effectively gain the height needed by the removal of the cribbage. This is quite easy. Feel free to contact me for any clarification of above. Keep us posted on what you find out.
Tailwinds...
Simplicity is the ultimate sophistication.
Leonardo Da Vinci
Working on a RV-4
Citabria 7GCBC
Cessna 180
RV7 I0-360 C/S, Slider, AP, Glass, etc. sold.
RV6 O-320 F/P, Slider, AP, Steam, etc., sold
Citabria 7KCAB rental
Piper Cherokee, sold
Sparrowhawk, sold
Proud -VAF- Supporter - Exempt, Dues Paid Anyway.
Old 03-05-2012, 07:39 AM
Richard@Langair Richard@Langair is offline
There is no way they could be switched and still be flyable. The toe out would be close to 30degrees if they were installed on the wrong sides.
Also, one easy way to check is, the hole for the brake mount should be level with the ground when installed. If you had them on the wrong side, it would be vertical (Or at least close to vertical).
If you are really concerned about tire wear, you may be able to work with Van's or their supplier to figure out if something is just on the edge of the manufacturing tolerance or if there was indeed a problem with one of the parts.
How many hours and landings do you get out of a set of tires right now before you have to change or flip them?
Last edited by Richard@Langair : 03-05-2012 at 07:45 AM. Reason: accidentally hit submit too soon!!
Old 03-05-2012, 03:03 PM
Working with Ken at Van's. Discovered our perceived problem Saturday at noon and could not wait till monday to find out if we screwed up. We have about 40 landings all on asphalt. They maybe could go Another ten before having to get flipped. Ken gave us some more things to check and we will do them tonight. I am backing up from the ledge now. Thanks for the help
Phelps
Kevin Phelps
Paid thru Dec 2020
RV-7A flying N782WP
Stuart, Fl
Old 03-05-2012, 03:15 PM
NickAir's Avatar
Default gear legs
Good to hear you have a possible fix.
Keep us posted so all may learn.
Tailwinds...
Leonardo Da Vinci
Working on a RV-4
Citabria 7GCBC
Cessna 180
Sparrowhawk, sold
