03-03-2012, 08:50 AM
Tip: G3i, & Those darn adel clamps ##!% SOLVED
Those darn adell clamps ##!% SOLVED
Came up with today with the frustration of holding two adell clamps with needle noses and hemostats. Tuff problem made easy with a small piece of metal.
Yeah!
03-03-2012, 08:54 AM
Thanks! I was wrestling them a couple days ago!
That simple idea you came up with would have come in handy!
Me thinks I will make one for the next time
John Mastro
RV-8
03-03-2012, 09:05 AM
clamps
I just safety them closed with thin safety wire and cut it off after installing hardware.
03-03-2012, 11:26 AM
This begs the question...
WHY are they springy? Does that serve some useful purpose? If so the reason escapes me.. Just seems they would be a lot easier to work with if they weren't THAT springy...
YMMV
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
03-03-2012, 12:58 PM
Thomas, That is a clever little trick!
I am soooooo gonna do that!
Thanks for sharing it!
 CJ
The experiment works!
03-03-2012, 01:51 PM
Adel clamps are kind of like your second grade teacher. All she wanted to do was teach us new vocabulary words!
Scott "Grumpy" Stewart
RV-7 N957RV (First Flight on Dec 18, 2009 )
#866 on the Van's RV-7 hobbs
#6563 on Van's generic hobbs
Arlington, WA
03-03-2012, 02:23 PM
As said earlier in a post, a loop of lock wire will also do the trick
Dennis Isaksson
G?llivare, Sweden
Grew up with an RV-4, SE-XIO
Now: RV-8, Showplanes Fastback. #83218 Under construction, SE-XXO
Engine and avionic installation in progress
03-03-2012, 06:43 PM
Great idea, why didn't I think of that, I've just struggled with needlenose & grunting but not any more, thanks for the tip.
