Landing light lens
Ron,
Nice, recent posting at http://www.vansairforce.com/communit...ad.php?t=83364 with link to pictures showing cutting / fitting wing tip lenses. My preference is to drill and tap a blob of flox places on the inside of the wingtip for the corner screws rather than use nut plates.
The cutout in the wing tip blocks light from the wing tips directly in front of the plane. IF you really want LIGHT I'd recommend mounting an HID in the leading edge of each wing, IE Duckworks.
Regards,
Roy
Roy
N174RT (RV-7A) first flight 5/31/11, 1780hrs as of August 2020:
Tip-up, Lycon IO-360 EXP, WW 74HRT, AFS 5600T, AF-Pilot, IFD440, SL-30, echoUAT, D100 for backup, CQ1 headsets, CMW E-Lift
Our other riveted aluminum monocoque RV is a 25' Airstream
Past aluminum monocoque vehicles:
N601RT (CH601HDS) First flight 5/03, 1550hrs after flying 8 years: 912ULS, GNS430W, SL-30, D10A Sold
1995 Midnight Pearl NSX w/BBSC Sold
EAA Chapter 105 board member 2010->2015
