Old 03-01-2012, 06:31 AM
Tailpilot Tailpilot is offline
Question Painting powder coated brackets
Stating my 8 build and was wondering. The brackets like hs411, are powder coated but I want to eventually paint them the same color as the plane. What is the best way to go about this? Do I just scotch brite them for now to put a rough surface?
Old 03-01-2012, 08:08 AM
RV7Ron's Avatar
RV7Ron RV7Ron is offline
Welcome to VAF!
Definitely scuff them...I used something along the lines of 150 grit sandpaper though and then painted with SW JetFlex cockpit paint. I also plan to do my engine mount to match my exterior and I've been told you can powdercoat right over the top of that as well with a good scuff job.
Ron Duren
Mechanical Engineer
"SportAir PhD"-RV Assembly/Composites/Electrical
Denver, CO (KBJC)
RV-7 'Tip Up'
Flying!! as of 3/16/14
IO-375/WW 200G-CS/SkyView/Dual P-mags
N531R "Wablosa" Wings of Red
http://www.ronsrv7project.blogspot.com
Old 03-01-2012, 08:57 PM
Ok...thanks. I'll just scuff them up and then when the plane gets painted all will be good to go.
