Hi guys,
wondering if you could help me out...
What wire size did you guys use for wiring the 5 cables of the Ray Allen Trim servo? #22 should be sufficient, right? Shielded, or not shielded?
And what about the TruTrak Autopilot Servos (Alttrak, Digitrak). Also #22 unshielded?
How did you make the connections for wires / tubes coming out of the wing routing into the fuselage? I?d like to make connections as wings should be removable...
Best wishes
Sunit
