Old 02-29-2012, 01:27 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Slick Start Wiring Help- IO540C4B5
Just given a used (but good) Slick Start, SS1001, Rev D --- Would like to put it on the RV-10, IO540C4B5 with Slick Mags, 6393, 6350 (no impulse on either). Standard key switch (Lft, Rt, Both, Start)
I think? the wiring is Pin 1 to "P" lead on left mag, Pin 4 to switched side of starter relay, and Pin 5 to ground.
I would appreciate your help to ensure I do not do something dumber than usual.
Ron
Old 02-29-2012, 01:32 PM
rocketbob's Avatar
http://www.aeroelectric.com/articles...erOfSparks.pdf
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 03-03-2012, 12:31 PM
RONSIM's Avatar
Default Bob, thanks
I believe from the link you sent me, I should be able to wire the way I mentioned and it should work --- will give it a try ---- certainly hope it takes care of the "hot" start problem.
