Old 02-29-2012, 08:29 AM
larrynew's Avatar
larrynew larrynew is offline
Default Install Steps BEFORE F-750 Aft Baggage Side Cover
Don't do what I did and read and comply with Van's instructions which said: 1. Install F-750 Aft Baggage Side Cover, 2. Refer to separate instructions for installing steps. Go to instructions for steps which say: 1. Remove F-750 Aft Baggage Side Cover! More practice drilling out rivets.
Larry New
RV-7A - Flying 900+ hrs
RV-10 - Flying 2.9 hrs
48 States in 7 Days!
VAF Paid - Annual Autodraft
Old 02-29-2012, 01:48 PM
Fred.Stucklen's Avatar
Fred.Stucklen Fred.Stucklen is offline
Default Steps
If you're really smart you'll install the steps with nutplates, and an additional inspection cover in the baggage compartment floor to accress the bolt in the nylon block under the floor. There have been many step failures (I've had two, both on the passenger side) and having the nutplates and access panel will make what is normally a full day job, into a one hour job when you have to replace the step....
Fred Stucklen
wstucklen1@cox.net
RV-7A N924RV Flying (1825 Hrs & counting)
RV-6A N926RV 875 Hrs (Sold)
RV-6A N925RV 2008 Hrs (Sold)
