Old 02-27-2012, 10:53 AM
Cadstat's Avatar
Cadstat Cadstat is offline
Default RPM green arc
The low end of the green arc is usually 20 that is 2000 RPM. I'll been told that is the lowest you want to operate because of cooling, combustion temps, lead on plugs, oil pressure, sustain flight, what ever... But that being said, that number might have more meaning pulling a 172 through the sky but it seems I can dial back the RV to 1800-1600 on a long approach without noticing any side effects. Any thoughts?
John D. Artz, EAA 71811, 100+ Young Eagle flts
Adopted Dave's 6A
MXL Ultralight, only bleeding after 3 landings
Scorpion Two Helicopter, big mistake
PA-28 and 210E Centurion
Old 02-27-2012, 11:01 AM
Andy Hill's Avatar
Andy Hill Andy Hill is offline
Wild guess, but I seem to recall when to use Carb Heat if appropriate? Not relevant to FI, and as you say, needs further interpretation if C/S...
Andy & Ellie Hill
RV-8 G-HILZ
RV-3B G-HILI very slow build
RV8tors
Old 02-27-2012, 11:15 AM
jbagley's Avatar
jbagley jbagley is offline
Maybe RV's have tighter cowls with less cooling than a 172? So, possibly our engines don't cool off as quickly at low rpm settings on a long approach? I'd be curious to know what rate of cooling (CHT's) is damaging to a Lycoming and do some post-flight analysis of EMS data.
The low power setting on a long approach situation seems somewhat unavoidable with a fixed pitch prop on an RV. Our airplanes are just too darn fast! Such a terrible predicament! Oh, what will we ever do?
James Bagley Jr
RV6A flying
RV6 #2 tail done and wings done
Old 02-27-2012, 01:53 PM
az_gila's Avatar
az_gila az_gila is offline
For a certified plane the FARs say the green arc defines the normal operating range.
However I can't find this range defined in my Lycoming O-360 Operators manual.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-27-2012, 02:16 PM
zilik's Avatar
zilik zilik is offline
VAF Moderator
My 6A with the hartzell prop is limited in the 2000-2250 rpm range for extended periods. This is a prop manufactures limitation. I know of no other limitations except the 2700 rpm limit imposed by Lycoming.
Gary "Seismo" Zilik
Pine Junction, Colorado
RV-6A N99PZ S/N 22993 SOLD
