Old 02-26-2012, 08:28 PM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default braided oil line chaffing
During a routine engine inspection with the top cowling off I noticed some significant chafing of a braided oil line with an unused flange on the oil cooler. When I fitted this line I anticipated that there might be some issue here but did not have the good sense to properly address it then.
After removing the lower cowling I was able to get a hack saw blade into position with my hands with enough travel to slowly work at removing the interference. I was pretty far into the cut when I thought to take some photos.
Here you can see where the line was grinding away at the flange with a couple of shots from the above and below.
After cleaning up the cut with some emery cloth I added some RTV on the line farther forward on the flat of the oil cooler where the line passes.
After putting everything back together I took a hangar row friend who is starting to have frustrations with his medical up for his first RV ride;
some of the best lines: "my plane won't do this!" and "man, that was fun... I think I almost wet myself!"
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 02-27-2012, 01:00 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
A short length of vinyl hose would fix the problem too.
Just split it and use ty-raps to secure it.
Those braided hoses can act like files under any vibration....
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-27-2012, 05:41 AM
Stephen---I assume that the braid wasnt broken, or the teflon liner wasnt exposed. Yep---when stainless steel rubs on anything, it can be damaged, just like anything else.
Change the hose.
Tom
Ridgeland, SC
Old 02-27-2012, 10:39 AM
paul mosher
Posts: n/a
Default clamps
It's too late now, but I would have used a MS21919 clamps to support that line to the cooler.
