Cus I'm an HVAC geek, here is psychrometric explanation.
When you burn fuel you make mostly CO2 and water vapour. During flight some of that mixture gets pushed past the rings into the crank case.
Air at high temperature can hold a LOT more moisture than cold air.
So you land and you have a nice hot engine at sy 180F. The air inside the crankase is completely saturated (I know this because when i hookup the dehumidifier and crack open the dipstick tube I column of STEAM rising from the tube).
This saturated air at 180F now begins to cool, hits the dewpoint at say 150F and now condenses the rest of the moisture inside the crankcase.. The condensation probably drips all over the camshaft... My Psych chart doesn't go up to 180F so I can't give you actual numbers of how much moisture would be inside the crankcase..but its a lot.
So the dehum unit does two things..It expels this steam out of the case (at least it does before it cools and condenses into liquid) and then it continues to flush the case with very dry air..This air is so dry it picks up moisture from wherever it can..I.e it will evaporate left over moisture after the engine is cooled.
if you run a small block heater this will increase the partial pressure of the moisture.i.e it will evaporate more easily.
This is why frequent flying is recommended to keep a film of oil splashed on the cam..The cam is above the oil level in the case. A dehum unit is a more direct way to achieve the same thing for really low cost.
There endeth the lesson..
Frank
