Wiring 430 to ki206
Question for anyone who might have this combination. According to the Garmin wiring diagram, Pin 32 on the 4001 connector goes to small c on the KI 206 connector. This pin is grounded according to my test. I checked the maintenance document for the KI 206 and it appears that pin Z should be the ground wire. These pins are connected to the rotor of the obs resolver. I would tend to believe the Garmin diagram but wanted to find out if anyone had any different pin discrepancies.
