Old 02-25-2012, 05:59 PM
Jim P's Avatar
Jim P Jim P is offline
Default Torquing Lower Engine Mount Bolts
I have an IO-360-M1 already installed, anyone have the easiest way to torque the lower right engine mount nut below #3? The oil tube base casting really gets in the way and even a crows foot isn't easy. I just did the shim for sag so I'm re-installing the bolts.
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 02-27-2012, 06:10 AM
mahlon_r mahlon_r is offline
Box end wrench normally works fine.
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
